Create layer with true Color in Lisp
Message 1 of 26
I have a routine that creates layers & assigns the color & linetype but now i have to create a few that have the true color instead of the standard autocad color index such as "0-255". Normally i would create a layer, assign it color 4 with a continuous linetype. How can i create a layer & assign it the color of "255,209,0" in lisp?
Here is a sample:
("K-BEV" "4" "CONTINUOUS")
("K-BEV-MISC" "11" "CONTINUOUS")
("K-CENT-CKEP" "4" "CONTINUOUS")
("K-CENT-XXEX" "4" "CONTINUOUS")
("K-CENT-XXXP" "4" "CONTINUOUS")
("K-CHAS-CKEP" "4" "CONTINUOUS")
("K-DEMO" "255,209,0" "HIDDEN4")
Replies (25)
Message 2 of 26
hak_vz
(defun truecolor (r g b)
 (+ (lsh (fix r) 16)
    (lsh (fix g) 8)
    (fix b)
(defun create_layer (name linetype r g b)
  (setq lyr (tblsearch "layer" name) col (truecolor r g b) )
  (if (not lyr)
    (entmake
      (list (cons 0 "layer")
      (cons 100 "acdbsymboltablerecord")
      (cons 100 "acdblayertablerecord")
      (cons 2 name)
      (cons 6 linetype)
      (cons 62 198)
      (cons 420 col)
      (cons 70 0)))
  (princ)
Usage:
(create_layer "K-DEMO" "HIDDEN4" 255 209 0)
I hope that's what you looking for!
At the time of layer creation you should have line type definition loaded.
If not use
(setvar "expert" 3)
(command "-linetype" "load" "*" "acad.lin" "")   ; or other
Miljenko Hatlak
Message 3 of 26
it might be but i do not understand all of the code. It looks like you are creating an entity with entmake & creating a list with some cons cells. What turns the layer color into 255,209,0 & what applies that to K-DEMO? Would i have to duplicate this code for the othe 3 layers that i need to have the true colors? I need to create these layers:
LAYER:                       COLOR          LINETYPE
K-DEMO                    255,209,0     HIDDEN 4
K-EQPM                     0,33,235      CONTINUOUS
K-EQPM-OPTIONAL   51,204,9      CONTINUOUS
K-EQPM-RELO           244,47,21    CONTINUOUS
Message 4 of 26
ronjonp
Try something like this:
(defun _addlayer (name color ltype plot / _rgb lt)
  (defun _rgb (l) (+ (lsh (fix (car l)) 16) (lsh (fix (cadr l)) 8) (fix (caddr l))))
  (cond	((not (tblsearch "layer" name))
	 (entmakex (list '(0 . "LAYER")
			 '(100 . "AcDbSymbolTableRecord")
			 '(100 . "AcDbLayerTableRecord")
			 '(70 . 0)
			 (cons 2 name)
			 (if (listp color)
			   (cons 420 (_rgb color))
			   (cons 62 color)
			 (cons 6
			       (if (tblsearch "ltype" ltype)
				 ltype
				 "continuous"
			 (cons 290 plot)
			 ;;1 = plottable 0 = not=plottable
	((tblobjname "layer" name))
;; (_addlayer "NewLayerName" '(69 69 69) "3Dash2" 1)
;; (_addlayer "NewLayerName2" 169 "3Dash2" 1)
Message 5 of 26
Would i be able to apply this to my existing routine? I apologize for my lack of knowledge, i am still trying to learn lisp. Here is how we currently create our layers
Message 6 of 26
ronjonp
Something like this should work:
			 '(70 . 0)
			 (cons 2 name)
			 (if (listp color)
			   (cons 62 color)
			 (cons 6
				 ltype
				 "continuous"
			 (cons 290 plot)
(mapcar	'(lambda (x) (_addlayer (car x) (cadr x) (caddr x) (last x)))
	'(("0" 9 "CONTINUOUS" 1)
	      ;; ** Example to create RGB layer **
	      ("A-ADA-ACC-EXST_RGB" (55 65 75) "CONTINUOUS" 1)
	      ("A-ADA-ACC-EXST" 9 "CONTINUOUS" 1)
	      ("A-ADA-ACC-NEW" 4 "CONTINUOUS" 1)
	      ("A-ADA-CLEAR" 223 "HIDDEN2" 1)
	      ("A-ADA-CLEAR-FIXT" 223 "HIDDEN2" 1)
	      ("A-ANNO-DIMS" 31 "CONTINUOUS" 1)
	      ("A-ANNO-REVS" 22 "CONTINUOUS" 1)
	      ("A-ANNO-TEXT" 31 "CONTINUOUS" 1)
	      ("A-ANNO-TTLB" 230 "CONTINUOUS" 1)
	      ("A-AREA-GROSS" 2 "CONTINUOUS" 1)
	      ("A-AREA-WORK" 252 "CONTINUOUS" 1)
	      ("A-CLNG-DEMO" 2 "HIDDEN2" 1)
	      ("A-CLNG-GRID" 9 "CONTINUOUS" 1)
	      ("A-CLNG-GRID-EXST" 9 "CONTINUOUS" 1)
	      ("A-CLNG-GRID-PATT" 143 "CONTINUOUS" 1)
	      ("A-CLNG-MISC" 3 "CONTINUOUS" 1)
	      ("A-CLNG-SHADE" 252 "CONTINUOUS" 1)
	      ("A-CLNG-SOFFIT-EXST" 4 "HIDDEN2" 1)
	      ("A-CLNG-SOFFIT-NEW" 3 "HIDDEN2" 1)
	      ("A-CNTR" 4 "CONTINUOUS" 1)
	      ("A-CNTR-NEW" 4 "CONTINUOUS" 1)
	      ("A-DEMO-GLAZ" 2 "HIDDEN2" 1)
	      ("A-DEMO-ITEM" 2 "HIDDEN2" 1)
	      ("A-DEMO-WALL" 2 "HIDDEN2" 1)
	      ("A-DET-HEAVY" 6 "CONTINUOUS" 1)
	      ("A-DET-LIGHT" 13 "CONTINUOUS" 1)
	      ("A-DET-MEDIUM" 3 "CONTINUOUS" 1)
	      ("A-DET-PATT" 143 "CONTINUOUS" 1)
	      ("A-DET-XHEAVY" 5 "CONTINUOUS" 1)
	      ("A-DET-XLIGHT" 9 "CONTINUOUS" 1)
	      ("A-DOOR-EXT-EXST" 3 "CONTINUOUS" 1)
	      ("A-DOOR-EXT-NEW" 14 "CONTINUOUS" 1)
	      ("A-DOOR-INT-EXST" 4 "CONTINUOUS" 1)
	      ("A-DOOR-INT-NEW" 12 "CONTINUOUS" 1)
	      ("A-ESD-DEMO" 2 "HIDDEN2" 1)
	      ("A-ESD-EXST" 163 "CONTINUOUS" 1)
	      ("A-ESD-GRID" 9 "CENTER2" 1)
	      ("A-ESD-GRID-IDEN" 31 "CONTINUOUS" 1)
	      ("A-ESD-HEAVY" 6 "CONTINUOUS" 1)
	      ("A-ESD-LIGHT" 13 "CONTINUOUS" 1)
	      ("A-ESD-MEDIUM" 3 "CONTINUOUS" 1)
	      ("A-ESD-PATT" 143 "CONTINUOUS" 1)
	      ("A-ESD-XHEAVY" 5 "CONTINUOUS" 1)
	      ("A-ESD-XLIGHT" 9 "CONTINUOUS" 1)
	      ("A-FIXT-EQPM" 9 "CONTINUOUS" 1)
	      ("A-FIXT-FLOR-EXST" 9 "CONTINUOUS" 1)
	      ("A-FIXT-FLOR-NEW" 4 "CONTINUOUS" 1)
	      ("A-FIXT-SIGN" 4 "CONTINUOUS" 1)
	      ("A-FLOR-AISLE" 143 "CONTINUOUS" 1)
	      ("A-FLOR-OTLN" 4 "CONTINUOUS" 1)
	      ("A-FLOR-PATT" 143 "CONTINUOUS" 1)
	      ("A-FLOR-RAIL" 9 "CONTINUOUS" 1)
	      ("A-GLAZ-EXST" 9 "CONTINUOUS" 1)
	      ("A-GLAZ-INT-EXST" 9 "CONTINUOUS" 1)
	      ("A-GLAZ-INT-NEW" 11 "CONTINUOUS" 1)
	      ("A-GLAZ-NEW" 11 "CONTINUOUS" 1)
	      ("A-GLAZ-SILL-EXST" 15 "CONTINUOUS" 1)
	      ("A-GLAZ-SILL-INT-EXST" 15 "CONTINUOUS" 1)
	      ("A-GLAZ-SILL-INT-NEW" 11 "CONTINUOUS" 1)
	      ("A-GLAZ-SILL-NEW" 11 "CONTINUOUS" 1)
	      ("A-ITEM-NO-PLOT" 223 "CONTINUOUS" 1)
	      ("A-ROOF-CNPY-NEW" 4 "CONTINUOUS" 1)
	      ("A-ROOF-EQPM" 9 "CONTINUOUS" 1)
	      ("A-ROOF-GUTTER" 9 "CONTINUOUS" 1)
	      ("A-ROOF-LADR-EXT" 9 "CONTINUOUS" 1)
	      ("A-ROOF-LADR-INT" 9 "CONTINUOUS" 1)
	      ("A-ROOF-OTLN" 3 "HIDDEN2" 1)
	      ("A-ROOF-OTLN-DEMO" 2 "HIDDEN2" 1)
	      ("A-ROOF-OTLN-EXST" 143 "HIDDEN2" 1)
	      ("A-ROOF-PARA" 2 "CONTINUOUS" 1)
	      ("A-ROOF-PATT" 143 "CONTINUOUS" 1)
	      ("A-ROOF-SCREEN" 9 "CONTINUOUS" 1)
	      ("A-ROOF-SHADE" 252 "CONTINUOUS" 1)
	      ("A-ROOF-SIGN-NEW" 4 "CONTINUOUS" 1)
	      ("A-ROOF-SLOP" 9 "CONTINUOUS" 1)
	      ("A-STAIR-RAIL" 9 "CONTINUOUS" 1)
	      ("A-STAIR-RAIL-NEW" 9 "CONTINUOUS" 1)
	      ("A-STAIR-RISER" 2 "HIDDEN2" 1)
	      ("A-STAIR-RISER-NEW" 2 "HIDDEN2" 1)
	      ("A-STAIR-TREAD" 2 "CONTINUOUS" 1)
	      ("A-STAIR-TREAD-NEW" 2 "CONTINUOUS" 1)
	      ("A-WALL-EXT-EXST" 7 "CONTINUOUS" 1)
	      ("A-WALL-EXT-FNSH" 4 "CONTINUOUS" 1)
	      ("A-WALL-EXT-NEW" 6 "CONTINUOUS" 1)
	      ("A-WALL-HEAD" 3 "HIDDEN2" 1)
	      ("A-WALL-INT-EXST" 7 "CONTINUOUS" 1)
	      ("A-WALL-INT-FNSH" 3 "CONTINUOUS" 1)
	      ("A-WALL-INT-NEW" 6 "CONTINUOUS" 1)
	      ("A-WALL-LOW-EXST" 9 "CONTINUOUS" 1)
	      ("A-WALL-LOW-NEW" 11 "CONTINUOUS" 1)
	      ("A-WALL-LOW-PATT" 143 "CONTINUOUS" 1)
	      ("A-WALL-OVHD-NEW" 3 "HIDDEN2" 1)
	      ("A-WALL-PATT" 143 "CONTINUOUS" 1)
	      ("A-WALL-PRHT" 3 "CONTINUOUS" 1)
	      ("A-WALL-SHADE" 252 "CONTINUOUS" 1)
	      ("A-WALL-SHADE-INT" 252 "CONTINUOUS" 1)
	      ("A-WALL-STUD" 4 "CONTINUOUS" 1)
	      ("A-WALL-UNDER" 4 "HIDDEN2" 1)
	      ("C-PKNG-AREA-CURB" 15 "CONTINUOUS" 1)
	      ("C-PKNG-AREA-IMP" 13 "CONTINUOUS" 1)
	      ("C-PKNG-AREA-LAND" 11 "CONTINUOUS" 1)
	      ("C-PKNG-AREA-PER" 15 "CONTINUOUS" 1)
	      ("C-PKNG-CURB-EXST" 4 "CONTINUOUS" 1)
	      ("C-PKNG-CURB-NEW" 3 "CONTINUOUS" 1)
	      ("C-PKNG-CURB-PATT" 143 "CONTINUOUS" 1)
	      ("C-PKNG-CURB-SHADE" 252 "CONTINUOUS" 1)
	      ("C-PKNG-LAND-EXST" 4 "CONTINUOUS" 1)
	      ("C-PKNG-LAND-NEW" 3 "CONTINUOUS" 1)
	      ("C-PKNG-STRP-EXST" 9 "CONTINUOUS" 1)
	      ("C-PKNG-STRP-NEW" 9 "CONTINUOUS" 1)
	      ("C-SITE-CARS" 9 "CONTINUOUS" 1)
	      ("C-SITE-DEMO-ITEM" 2 "HIDDEN2" 1)
	      ("C-SITE-EQPM" 7 "CONTINUOUS" 1)
	      ("C-SITE-PATT" 143 "CONTINUOUS" 1)
	      ("C-SITE-PROPLINE" 2 "DASHDOT" 1)
	      ("C-SITE-UTILITIES-EXST" 4 "HIDDEN2" 1)
	      ("C-SITE-UTILITIES-NEW" 3 "HIDDEN2" 1)
	      ("C-SITE-SHADE" 252 "CONTINUOUS" 1)
	      ("C-SITE-SIGN" 2 "CONTINUOUS" 1)
	      ("DEFPOINTS" 223 "CONTINUOUS" 1)
	      ("E-CCTV" 3 "CONTINUOUS" 1)
	      ("E-COND" 3 "CONTINUOUS" 1)
	      ("E-HVAC-EQP" 2 "CONTINUOUS" 1)
	      ("E-IT" 3 "CONTINUOUS" 1)
	      ("E-IT-POWR" 3 "CONTINUOUS" 1)
	      ("E-IT-TEXT" 31 "CONTINUOUS" 1)
	      ("E-LGHT" 2 "CONTINUOUS" 1)
	      ("E-LGHT-IDEN" 31 "CONTINUOUS" 1)
	      ("E-LGHT-ROOF" 2 "CONTINUOUS" 1)
	      ("E-LGHT-SOFF" 2 "CONTINUOUS" 1)
	      ("E-LITE-EMER" 3 "CONTINUOUS" 1)
	      ("E-LITE-EXT-EXST" 3 "CONTINUOUS" 1)
	      ("E-LITE-EXT-NEW" 3 "CONTINUOUS" 1)
	      ("E-LITE-EXT-ROOF" 3 "CONTINUOUS" 1)
	      ("E-LITE-FIXT-KITCHEN" 9 "CONTINUOUS" 1)
	      ("E-LITE-FLUR" 3 "CONTINUOUS" 1)
	      ("E-LITE-FLUR-EXST" 9 "CONTINUOUS" 1)
	      ("E-LITE-IDEN" 31 "CONTINUOUS" 1)
	      ("E-LITE-NOTE" 31 "CONTINUOUS" 1)
	      ("E-LITE-SECU" 6 "CONTINUOUS" 1)
	      ("E-LITE-SITE-NEW" 3 "CONTINUOUS" 1)
	      ("E-LITE-TRAC" 3 "CONTINUOUS" 1)
	      ("E-LITE-WIRE" 31 "CONTINUOUS" 1)
	      ("E-PNL" 3 "CONTINUOUS" 1)
	      ("E-POWR" 3 "CONTINUOUS" 1)
	      ("E-POWR-ROOF" 3 "CONTINUOUS" 1)
	      ("E-POWR-SWITCH" 3 "CONTINUOUS" 1)
	      ("E-POWR-WIRE" 2 "CONTINUOUS" 1)
	      ("E-PPWR-DIMS" 4 "CONTINUOUS" 1)
	      ("E-PPWR-ROOF-TEXT" 31 "CONTINUOUS" 1)
	      ("E-PPWR-SYMB" 3 "CONTINUOUS" 1)
	      ("E-PPWR-TEXT" 31 "CONTINUOUS" 1)
	      ("E-ROOF-NOTE" 31 "CONTINUOUS" 1)
	      ("E-ROOF-WIRE" 31 "CONTINUOUS" 1)
	      ("E-SITE-POWR" 3 "CONTINUOUS" 1)
	      ("E-SITE-POWR-TEXT" 31 "CONTINUOUS" 1)
	      ("E-SOUN" 3 "CONTINUOUS" 1)
	      ("E-SWCH" 3 "CONTINUOUS" 1)
	      ("F-ALRM-NOTE" 31 "CONTINUOUS" 1)
	      ("F-FIXT" 4 "CONTINUOUS" 1)
	      ("F-PROT-EQPM" 3 "CONTINUOUS" 1)
	      ("F-SPRN" 3 "CONTINUOUS" 1)
	      ("K-EQPH-CKXX" 4 "CONTINUOUS" 1)
	      ("K-EQPH-XXEP" 4 "CONTINUOUS" 1)
	      ("K-EQPH-XXEX" 4 "PHANTOM" 1)
	      ("K-EQPM-BLOK" 4 "CONTINUOUS" 1)
	      ("K-EQPM-BLOK-EXST" 255 "CONTINUOUS" 1)
	      ("K-EQPM-CASH" 4 "CONTINUOUS" 1)
	      ("K-EQPM-CKXX" 4 "CONTINUOUS" 1)
	      ("K-EQPM-CURB" 4 "CONTINUOUS" 1)
	      ("K-EQPM-EXST" 252 "CONTINUOUS" 1)
	      ("K-EQPM-GRILL" 4 "CONTINUOUS" 1)
	      ("K-EQPM-IDEN" 31 "CONTINUOUS" 1)
	      ("K-EQPM-MENU" 4 "HIDDEN2" 1)
	      ("K-EQPM-MISC" 11 "CONTINUOUS" 1)
	      ("K-EQPM-NEW" 4 "CONTINUOUS" 1)
	      ("K-EQPM-OPTIONAL-XXEP" 82 "PHANTOM4" 1)
	      ("K-EQPM-POS" 4 "CONTINUOUS" 1)
	      ("K-EQPM-RELO" 1 "CONTINUOUS" 1)
	      ("K-EQPM-RELO-XXEP" 1 "CONTINUOUS" 1)
	      ("K-EQPM-SAFE" 4 "CONTINUOUS" 1)
	      ("K-EQPM-XXEP" 170 "CONTINUOUS" 1)
	      ("K-EQPO-CKEP" 4 "CONTINUOUS" 1)
	      ("K-EQPO-CKEX" 4 "CONTINUOUS" 1)
	      ("K-EQPO-CKXX" 4 "CONTINUOUS" 1)
	      ("K-FRZH-XXEP" 4 "CONTINUOUS" 1)
	      ("K-FRZR-CKXX" 4 "CONTINUOUS" 1)
	      ("K-FRZR-CKXX-DOOR" 4 "CONTINUOUS" 1)
	      ("K-PCVR-DIMS" 4 "CONTINUOUS" 1)
	      ("K-PCVR-SYMB" 4 "CONTINUOUS" 1)
	      ("K-PCVR-TEXT" 4 "CONTINUOUS" 1)
	      ("K-PKIT-DIMS" 4 "CONTINUOUS" 1)
	      ("K-PKIT-SYMB" 3 "CONTINUOUS" 1)
	      ("K-PKIT-TEXT" 3 "CONTINUOUS" 1)
	      ("K-ROOF-EQPM-NEW" 3 "CONTINUOUS" 1)
	      ("M-ANNO-DIMS" 31 "CONTINUOUS" 1)
	      ("M-ANNO-TEXT" 31 "CONTINUOUS" 1)
	      ("M-CHAS-CENT" 2 "CENTER2" 1)
	      ("M-DUCT" 2 "CONTINUOUS" 1)
	      ("M-DUCT-CENT" 4 "CENTER8" 1)
	      ("M-DUCT-CENT-EXST" 2 "CENTER8" 1)
	      ("M-DUCT-CENT-NEW" 2 "CENTER8" 1)
	      ("M-DUCT-DMPR" 2 "CONTINUOUS" 1)
	      ("M-DUCT-FITT" 3 "CONTINUOUS" 1)
	      ("M-DUCT-FLEX" 2 "CONTINUOUS" 1)
	      ("M-DUCT-HOOD" 2 "CONTINUOUS" 1)
	      ("M-DUCT-HOOD-EXST" 2 "CONTINUOUS" 1)
	      ("M-DUCT-HOOD-NEW" 2 "CONTINUOUS" 1)
	      ("M-DUCT-HOOD-RELO" 2 "CONTINUOUS" 1)
	      ("M-DUCT-IDEN" 3 "CONTINUOUS" 1)
	      ("M-DUCT-INSL" 2 "CONTINUOUS" 1)
	      ("M-DUCT-NOTE" 31 "CONTINUOUS" 1)
	      ("M-FITT" 6 "CONTINUOUS" 1)
	      ("M-HOOD" 2 "CONTINUOUS" 1)
	      ("M-HOOD-DUCT" 2 "CONTINUOUS" 1)
	      ("M-HVAC-CDFF" 2 "CONTINUOUS" 1)
	      ("M-HVAC-CDFF-DUCT" 2 "CONTINUOUS" 1)
	      ("M-HVAC-CDFF-NEW" 3 "CONTINUOUS" 1)
	      ("M-HVAC-CLEAR" 4 "HIDDEN2" 1)
	      ("M-HVAC-CLNG" 2 "CONTINUOUS" 1)
	      ("M-HVAC-DMPR" 5 "DGN Style 2" 1)
	      ("M-HVAC-DUCT" 5 "DGN Style 2" 1)
	      ("M-HVAC-EQPM" 8 "HIDDEN2" 1)
	      ("M-HVAC-FLOR" 2 "CONTINUOUS" 1)
	      ("M-HVAC-NOTE" 31 "CONTINUOUS" 1)
	      ("M-PHVA-DIMS" 4 "CONTINUOUS" 1)
	      ("M-PHVA-SYMB" 3 "CONTINUOUS" 1)
	      ("M-PHVA-TEXT" 3 "CONTINUOUS" 1)
	      ("M-ROOF-EQPM-CLEAR" 4 "HIDDEN2" 1)
	      ("M-ROOF-EQPM-DEMO" 7 "HIDDEN2" 1)
	      ("M-ROOF-EQPM-EXST" 7 "CONTINUOUS" 1)
	      ("M-ROOF-EQPM-EXST-CURB" 1 "HIDDEN4" 1)
	      ("M-ROOF-EQPM-EXST-DROP" 1 "HIDDEN4" 1)
	      ("M-ROOF-EQPM-IDEN" 31 "CONTINUOUS" 1)
	      ("M-ROOF-EQPM-NEW" 3 "CONTINUOUS" 1)
	      ("M-ROOF-EQPM-NEW-CURB" 3 "HIDDEN4" 1)
	      ("M-ROOF-EQPM-NEW-DROP" 3 "HIDDEN4" 1)
	      ("M-ROOF-EQPM-TEXT" 31 "CONTINUOUS" 1)
	      ("M-ROOF-NOTE" 31 "CONTINUOUS" 1)
	      ("P-CENT" 4 "CONTINUOUS" 1)
	      ("P-DOMW-COLD" 160 "DOMESTIC_COLD_WATER" 1)
	      ("P-DOMW-COLD-N" 160 "DOMESTIC_COLD_WATER" 1)
	      ("P-DOMW-FILT" 161 "CONTINUOUS" 1)
	      ("P-DOMW-FILT-N" 161 "CONTINUOUS" 1)
	      ("P-DOMW-FIXT" 4 "CONTINUOUS" 1)
	      ("P-DOMW-H110" 210 "2DASHES" 1)
	      ("P-DOMW-H110-N" 210 "2DASHES" 1)
	      ("P-DOMW-H140" 20 "DOMESTIC_HOT_WATER" 1)
	      ("P-DOMW-H140-N" 20 "DOMESTIC_HOT_WATER" 1)
	      ("P-DOMW-NOTE" 31 "CONTINUOUS" 1)
	      ("P-FIXT" 4 "CONTINUOUS" 1)
	      ("P-FIXT-ABOV" 4 "CONTINUOUS" 1)
	      ("P-FIXT-EXST" 9 "CONTINUOUS" 1)
	      ("P-FIXT-FILT" 3 "CONTINUOUS" 1)
	      ("P-FIXT-NEW" 4 "CONTINUOUS" 1)
	      ("P-FIXT-NOTE" 31 "CONTINUOUS" 1)
	      ("P-FIXT-RELO" 4 "CONTINUOUS" 1)
	      ("P-FIXT-XXEX" 4 "CONTINUOUS" 1)
	      ("P-GAS" 4 "CONTINUOUS" 1)
	      ("P-GAS-FIXT" 4 "CONTINUOUS" 1)
	      ("P-GAS-NOTE" 31 "CONTINUOUS" 1)
	      ("P-PFLR-DIMS" 4 "CONTINUOUS" 1)
	      ("P-PFLR-LEAD" 4 "CONTINUOUS" 1)
	      ("P-PFLR-SYMB" 3 "CONTINUOUS" 1)
	      ("P-PFLR-TEXT" 3 "CONTINUOUS" 1)
	      ("P-PLMB" 3 "CONTINUOUS" 1)
	      ("P-PLMB-ROOF" 3 "CONTINUOUS" 1)
	      ("P-PLMB-ROUGH" 3 "CONTINUOUS" 1)
	      ("P-PLMB-SERV-GAS" 44 "PHANTOM4" 1)
	      ("P-PLMB-SERV-SANG" 191 "UNDERGROUND_GSANITARY" 1)
	      ("P-PLMB-SERV-SANS" 190 "UNDERGROUND_SANITARY" 1)
	      ("P-PLMB-SERV-VENT" 2 "CONTINUOUS" 1)
	      ("P-PLMB-SERV-WTR-COLD" 160 "CENTER2" 1)
	      ("P-PLMB-SERV-WTR-COLDF" 161 "CENTER4" 1)
	      ("P-PLMB-SERV-WTR-HOT" 20 "HIDDEN2" 1)
	      ("P-PLMB-SERV-WTR-HOTT" 210 "HIDDEN4" 1)
	      ("P-PLMB-SERV-STRM" 160 "CENTER2" 1)
	      ("P-ROOF-VENT" 3 "CONTINUOUS" 1)
	      ("P-SAN-FIXT" 4 "CONTINUOUS" 1)
	      ("P-SAN-NOTE" 31 "CONTINUOUS" 1)
	      ("P-SANR-EQPM" 4 "CONTINUOUS" 1)
	      ("P-SANR-SYMB" 3 "CONTINUOUS" 1)
	      ("P-SLAB" 3 "CONTINUOUS" 1)
	      ("P-SODA" 190 "FENCELINE1" 1)
	      ("P-SPRK" 60 "HIDDEN4" 1)
	      ("P-SPRK-FIXT" 3 "CONTINUOUS" 1)
	      ("P-SPRK-NOTE" 31 "CONTINUOUS" 1)
	      ("P-STRM" 3 "CONTINUOUS" 1)
	      ("P-STRM-FIXT" 3 "CONTINUOUS" 1)
	      ("P-STRM-NOTE" 31 "CONTINUOUS" 1)
	      ("P-STRM-ROOF" 3 "CONTINUOUS" 1)
	      ("P-SYMB" 3 "CONTINUOUS" 1)
	      ("P-UGRD-DIMS" 4 "CONTINUOUS" 1)
	      ("P-UGRD-SYMB" 3 "CONTINUOUS" 1)
	      ("P-UGRD-TEXT" 3 "CONTINUOUS" 1)
	      ("P-VENT" 3 "CONTINUOUS" 1)
	      ("S-COLS-EXST" 2 "CONTINUOUS" 1)
	      ("S-COLS-NEW" 6 "CONTINUOUS" 1)
	      ("S-CONC-CURB" 3 "CONTINUOUS" 1)
	      ("S-CONC-CURB-PATT" 143 "CONTINUOUS" 1)
	      ("S-DEMO-ITEM" 2 "HIDDEN2" 1)
	      ("S-FLOR-BEAM-EXST" 4 "CENTER2" 1)
	      ("S-FLOR-BEAM-NEW" 10 "CENTER2" 1)
	      ("S-FLOR-FRAM-EXST" 4 "CONTINUOUS" 1)
	      ("S-FLOR-FRAM-NEW" 3 "CONTINUOUS" 1)
	      ("S-FNDN-EXST" 3 "CONTINUOUS" 1)
	      ("S-FNDN-NEW" 6 "CONTINUOUS" 1)
	      ("S-FNDN-OUTLINE" 3 "HIDDEN2" 1)
	      ("S-FNDN-PATT" 143 "CONTINUOUS" 1)
	      ("S-FOOTING-EXST" 2 "HIDDEN2" 1)
	      ("S-FOOTING-NEW" 4 "HIDDEN2" 1)
	      ("S-GRID-EXST" 9 "CENTER2" 1)
	      ("S-GRID-IDEN-EXST" 31 "CONTINUOUS" 1)
	      ("S-GRID-IDEN-NEW" 31 "CONTINUOUS" 1)
	      ("S-GRID-NEW" 11 "CENTER2" 1)
	      ("S-ROOF-BEAM-EXST" 4 "CENTER2" 1)
	      ("S-ROOF-BEAM-NEW" 10 "CENTER2" 1)
	      ("S-ROOF-FRAM-EXST" 4 "CONTINUOUS" 1)
	      ("S-ROOF-FRAM-NEW" 3 "CONTINUOUS" 1)
	      ("S-SECTY-FIXT" 3 "CONTINUOUS" 1)
	      ("S-SECTY-NOTE" 31 "CONTINUOUS" 1)
	      ("S-SLAB-LEVL" 4 "CONTINUOUS" 1)
	      ("S-WALL-FRAM-EXST" 4 "CONTINUOUS" 1)
	      ("S-WALL-FRAM-NEW" 3 "CONTINUOUS" 1)
	      ("SYMB" 3 "CONTINUOUS" 1)
	      ("TEXT" 31 "CONTINUOUS" 1)
Message 7 of 26
I'm going to break this down & see if i can understand it. i appreciate the help
Message 8 of 26
hak_vz
No. I+ve created a function that looks in layers table to see if layer with a name exist. If it don't it creates new layer .
In your code insert my function and create how many layers you want by calling function
(create_layer "K-EQPM"  "CONTINUOUS" 0 33 235)
(create_layer "K-EQPM-OPTIONAL"  "CONTINUOUS" 51 204 9)
(create_layer "K-EQPM-RELO" "continuous" 244 47 21)
Miljenko Hatlak
Message 9 of 26
hak_vz
Just put my code to the top or bottom of the list in your code.
Copy code for creating those layers and
In your list delete rows that are there to create layers with truecolor.
Miljenko Hatlak
Message 10 of 26
Thanks for the help. i will print your code out  & try to understand what you did. i appreciate the help
Message 11 of 26
Looks like this only works if the layer is not already in the drawing. Also i discovered that if the linetype is not already in my acad.lin file it also does not work. I have had this issue before.
Message 12 of 26
ronjonp
Try this instead. Will attempt to load the linetype if found in the acad*.lin file and if the layer exists, it will update the properties.
(defun _addlayer (name color ltype plot / _loadlinetype _rgb d e)
  ;; RJP - 04.03.2018
  ;; Creates or updates a layer
  (defun _loadlinetype (linetype / lt out)
    (cond ((tblobjname "ltype" linetype) t)
	  ((setq lt (vla-get-linetypes (vla-get-activedocument (vlax-get-acad-object))))
	   (setq out (vl-catch-all-apply
		       'vla-load
		       (list lt
			     linetype
			     (findfile (if (= 0 (getvar 'measurement))
					 "acad.lin"
					 "acadiso.lin"
	   (not (vl-catch-all-error-p out))
  (setq	d (apply 'append
		 (list (if (setq e (tblobjname "layer" name))
			 (entget e '("*"))
			       '(70 . 0)
		       (list (cons 2 name)
			     (if (listp color)
			       (cons 62 color)
			     (cons 6
				   (if (_loadlinetype ltype)
				     ltype
				     "continuous"
			     (cons 290 plot)
  (if e
    (entmod d)
    (entmakex d)
(vl-load-com)
;; (_addlayer "NewLayerName3" '(89 88 88) "Hidden2" 1)
;; (_addlayer "NewLayerName3" 7 "Foo" 0)
Message 13 of 26
yeh thanks. That's a problem that i have had. I didn't realize it until later that if you don't have the linetype defined in the acad.lin file it defaults to continuous
Message 14 of 26
hak_vz
Yes. It only works if layer isn't in a drawing, since you can not create two layers with same name  - first row in a script (tblsearch "layer" name).
 So you have to delete rows in your script that create layers with true color I sayed.
About linetype.  Hidden4 is not standard definition (maybe I'm wrong). Copy its definition in acad line, or put autolisp code that I provided on the top of your list.
(setvar "expert" 3)
(command "-linetype" "load" "*" "acad.lin" "")  ; or any other linetype definition here
 (+ (lsh (fix r) 16)
    (lsh (fix g) 8)
    (fix b)
  (if (not lyr)
    (entmake
      (cons 2 name)
      (cons 6 linetype)
      (cons 62 198)
      (cons 420 col)
      (cons 70 0)))
  (princ)
- Your script here
This was all you had to do.
I would create empty drawing with all layers , text sizes and so on created.
Miljenko Hatlak
Message 15 of 26
Thanks. We have a template that has everything in it but sometimes things get purged or something so this routine creates everything again. I might make this a separate routine & experiment with it. I have since convinced my coworkers to just go with index colors since that already works & it is much more simple to work with in lisp. There are still situations where i can use the true color so i would like to get something to work. For instance we do some elevations where we want to use true colors & it would be good to have something to set up everything if things get lost.
Message 16 of 26
hak_vz
I agree. I also prefer indexed colors.
In this routine that creates layer list I would also include lineweights.
Now you have all lineweights set to "default".
Miljenko Hatlak
Message 17 of 26
We do have some elevations that we do in color which we use the true color. We set the lineweight in our ctb file according to the color. i do have to figure out how to add some linetypes to the acad.lin file because it its a blank drawing & the line type is not in the drawing it uses the default which is continuous.
Message 18 of 26
Kent1Cooper
@Anonymous wrote:
... the line type is not in the drawing it uses the default which is continuous.
In (entmake)ing a Layer [at least in Acad2016 I have here], it doesn't even do that, but simply does not create the Layer at all.  It does  at least create it, and default to Continuous if it doesn't find the specified linetype, when using (command "_.layer" "_make" ....) [or "_new"].
BUT another advantage of the (command)-function way is that if  the specified linetype is in acad.lin, it does not  even need to be loaded into the drawing first -- it will find it, which (entmake) isn't smart enough to do.  [That's why I said "if it doesn't find the specified linetype" above, rather than "if the linetype is not loaded."]
However, if you have a very large number of Layers, the (command) approach could take noticeably longer than the (entmake) approach.  That can be lessened by not doing each one separately, but applying options to comma-delimited multiple-Layer-name strings, for example in your sampling [other than the one TrueColor Layer]:
(command "_.layer"
  "_new" "K-BEV,K-BEV-MISC,K-CENT-CKEP,K-CENT-XXEX,K-CENT-XXXP,K-CHAS-CKEP"
  "_color" 4 "K-CENT-CKEP,K-CENT-XXEX,K-CENT-XXXP,K-CHAS-CKEP"
  "_color" 11 "K-BEV-MISC"
And you never have to assign  Continuous as a linetype in the (command) approach as you do with (entmake) -- only non-continuous types.
Another advantage is that it won't matter if a Layer is already in the drawing.
Kent Cooper, AIA
Message 19 of 26
ronjonp
This CODE here should do what you want ( RGB or index colors ).
;; Truecolor example
;; Index example .. will default to continuous linetype since 'foo' is not defined in the acad.lin and will not plot ( 0 at the end )
;; Example to iterate a list
(foreach layer (list ("NewLayerName3" '(89 88 88) "Hidden2" 1)
		     ("NewLayerName4" 7 "Foo" 0)
		     ("NewLayerName5" '(0 0 255) "Dashed" 1)
  (_addlayer (car layer) (cadr layer) (caddr layer) (last layer))
Easy peasy 🙂
Message 20 of 26
hak_vz
OK. Before we jump into editing acad.lin
At the top of your layer generation script add next line
Or if you want to just load some lintype
(command "-linetype" "load" "dashed" "acad.lin" "")
(command "-linetype" "load" "border" "acad.lin" "")
Then open a new empty drawing and check if all layers are generated correctly
in regard linetype definition. When you open new drawing just few definitions are
loaded but we want to be sure that all linetype definitions are preloaded.
If some linetype definition is missing I'll explain how to add additional linetype
definitions to acad.lin
Miljenko Hatlak
