behavior of (ascii) function in AutoLISP
alex_b
Message 1 of 8
alex_b
Hi
Please consider the expression (ascii char) where char is a one-character string.
If char is in the extended ASCII set, I get different results depending on the OS:
On Acad 12 running under WinXP the result is the ASCII code of char.
OTH, on Acad12 running under Win 7, the result is a string consisting of the Unicode code for the character (\U+nnnn)
Any ideas?
alex
Replies (7)
Message 2 of 8
martti.halminen
AutoCAD R 12 is ancient history, and even AutoCAD 2012 is now an unsupported product.
Likewise Windows XP, and probably even Windows 7 to some extent.
So the only thing you can do is to write whatever is using the result to check the type and change its behaviour accordingly.
Message 3 of 8
alex_b
Thank you, although your answer doesn't help much.
The question was not so much to look for a solution, but to explain the inconsistent behavior of the same Lisp function, in the same Autocad version, on two different systems.
Is there a document giving exact specifications of AutoLisp functions?
alex
Message 4 of 8
ActivistInvestor
alex
Is this for any character or specific ones?  If it is any character, I don't see that on AutoCAD 2012/Windows 7 or AutoCAD 2017/Windows 10.  If it's not for all characters, then indicate which characters it happens with.
Message 5 of 8
rkmcswain
Do you mean the Developer's Guide?
There may be more details available to ADN Members, but I'm not sure.
Message 6 of 8
alex_b
For ASCII characters (0-127) it works OK on both platforms.
The problem occurs with extended ASCII (128-255), specifically Hebrew;
I did a bit of debugging and the problem is not with (ascii). Instead:
 (strlen (setq txt "א")) outputs 7.on Win 7 and 1 on WinXP.
Parsing the string gives \\U+05D0 which is, of course, the Unicode code of א,
but why should it be different in Win7 than in XP?
Any ideas?
Message 7 of 8
ActivistInvestor
Any ideas?
I suppose that could be a bug. I don't have a copy of XP with AutoCAD installed to test with, and don't think Windows XP has ever fully-supported UNICODE. It ma also have something to do with regional settings on the system.
Message 8 of 8
alex_b
There is no need for XP. In XP it works fine.
THe problem is under Win7.
And the regional settings are the same on both machines.
