Message 1 of 22
12:09 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello everyone! I found this AutoLisp on one of the forums to label lines with a bearing and distance callout... created by: Bruno Valsecchi.
This is attached as (Original Lisp)... This uses the (plab) command to use any line you choose and bring up the units pop up and label each line with the bearing and distance callout, which works amazing.
I updated some things and changed the command to (label). This is also attached.
I was wondering if anyone could adjust my updated lisp to fit with a better orientation to fit within smaller lines? As shown below:
