Circles from list file
Philip-John
Philip-John
I found a lisp by Lee Mac to draw circles from a list file (visit link below).
visit link
Can anybody modify the same to insert serial number also inside the drawn circle.
ВeekeeCZ
Not really sure why you won't ask there, but since you didn't post some example of a source txt file and a dwg of desired output.
dbhunia
Try with this......(It will insert number with default text style)
(defun c:circlesfromfile ( / i file line )
    (if
        (and
            (setq file (getfiled "Select Data File" "" "txt" 16))
            (setq file (open file "r"))
        (progn
            (setq i 0)
            (while (setq line (read-line file))
                (if
                    (and
                        (setq line (LM:str->lst line " "))
                        (= 3 (length line))
                        (setq line (mapcar 'distof line))
                        (vl-every 'numberp line)
                        (setq i (1+ i))
                    (entmakex
                        (list
                            (cons 0 "CIRCLE")
                            (list 10 (car line) (cadr line) 0.0)
                            (cons 40 (/ (caddr line) 2.0))
		(command "text" "J" "MC" "_none" (list (car line) (cadr line) 0.0) "" "" i);It also can be done with entmake
            (setq file (close file))
            (princ (strcat "\n" (itoa i) " Circle(s) Created."))
    (princ)
;;-------------------=={ String to List }==-------------------;; ;; ;; ;; Separates a string into a list of strings using a ;; ;; specified delimiter string ;; ;;------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2010 - www.lee-mac.com ;; ;;------------------------------------------------------------;; ;; Arguments: ;; ;; str - string to process ;; ;; del - delimiter by which to separate the string ;; ;;------------------------------------------------------------;; ;; Returns: A list of strings ;; ;;------------------------------------------------------------;; (defun LM:str->lst ( str del / pos ) (if (setq pos (vl-string-search del str)) (cons (substr str 1 pos) (LM:str->lst (substr str (+ pos 1 (strlen del))) del)) (list str) ) )
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Philip-John
Thanks dbhunia..
That is what I requested..
