Visual LISP, AutoLISP and General Customization
Batch Audit/Purge
7 REPLIES 7
Message 1 of 8
CADguy82
5107 Views, 7 Replies
Batch Audit/Purge
Does anyone know of any Lisp Routine or Program that allows you to Audit and/or Purge a whole bunch of drawings at once?
7 REPLIES 7
Message 2 of 8
in reply to: CADguy82
You could write a script that opens each one, audits, purges, and saves.
If you were to consider third party software, take a look at
http://www.dotsoft.com/dwgpurge.htm.
Terry
Message 3 of 8
You are the first person to get to use this program outside of my company... enjoy....
Requires DOSLIB.....
Jim
Do not download this file, please see next post...
Message 4 of 8
Sorry, quick change needed....
Please download this file instead....
Jim
Message 5 of 8
CADguy82
The file didn't work...bad line.
I combined two scripts yesterday that were given to me at the AUGI Forums. This routine Purges and Audits numerous drawings within the same folder. Check it out.
Message 6 of 8
Yes, that is essentially what my script does except mine will allow you to select files from any folder on your computer, not just the current folder.
Message 7 of 8
Download AutoDesks
Migration Tools (2006)
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=4091678&linkID=2475161
or Migration Assistance (2002)
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2887284&linkID=2475323
They come with ScriptPro
Then use this:
audit
y
-purge
a
n
_qsave
Message 8 of 8
I have used the "multi-batch" program for years for doing such things and a whole lot more. You can set the script up to up rev drawings, change title block attributes, purge, audit, save and plot all in one go if you want to. The best time saver i have ever used.
Forma Design Contest
AutoCAD Beta
