bad SSGET error list
diogo-braz
Message 1 of 8
diogo-braz
This line of code works fine in BricsCAD, but when I try to run it in AutoCAD, it doesn't work. Someone can help why I'm having this problem?
(setq lista (ssget (list (cons -4. "<or") (cons 0. "TEXT") (cons 0. "MTEXT") (cons -4. "or>"))))
"; error: bad SSGET list"
Replies (7)
Message 2 of 8
J-Rocks
Remove the point like this:
(cons -4 "<or") (cons 0 "TEXT") (cons 0 "MTEXT") (cons -4 "or>")
Although this is enough:
(ssget '((0 . "TEXT,MTEXT")))
Message 3 of 8
johnyDFFXO
It needs integers, not reals. Remove dots from all code numbers -4. / 0.
Message 4 of 8
diogo-braz
Thank you, it worked fine
Message 5 of 8
johnyDFFXO
Ohh, I see where the point is coming from...
it's (cons 0 "TEXT") vs '(0 . "TEXT")
In the case of quoted dotted pair is the point necessary but must be separated by spaces from both sides.
Message 6 of 8
DannyNL
It's even possible to use a wildcard 😀
(ssget '((0 . "*TEXT")))
Message 7 of 8
J-Rocks
Be mindful of RTEXT. 😂
Message 8 of 8
DannyNL
You are right about RTEXT, but in the 30+ years I've been working with AutoCAD I've maybe seen it once. Which doesn't mean it isn't used (n=1) and there might be some use for it.
IMO, if you use RTEXT, it should only be used to 'import' text files and then explode it to MTEXT asap.
Otherwise you will have additional reference files to send to your clients, which can easily be forgotten leaving the client without all the information 😁
