function command with variable length tokens or arguments
hoseobshim
Message 1 of 9
hoseobshim
Autocad command "ucs" has various options available.
How can I enable users to set the UCS using various options and return to my subsequent lines of code?
(setq worlducs_old (getvar "worlducs"))
(command "ucs") ;
(how-do-I-know-the-ucs-done ?) ; waiting until the user completes the ucs command
(setq worlducs_new (getvar "worlducs"))
Accepted solutions (3)
Replies (8)
Message 2 of 9
komondormrex
using acet.
(setq done 7)
(while (/= 6 done)
	(command-s "_ucs" pause)
	(setq done (acet-ui-message "Are you done?" "UCS change" 4))
Message 3 of 9
Kent1Cooper
@hoseobshim wrote:
....How can I enable users to set the UCS using various options and return to my subsequent lines of code?
(command "_.ucs"); leaves you in the command
(while (> (getvar 'cmdactive) 0) (command pause)); keeps pausing for user input until command is completed
(setq worlducs .... ; then go on
Or in new-enough versions, simply:
(command-s "_.ucs"); waits for user input until done
Kent Cooper, AIA
Message 4 of 9
Sea-Haven
You could incorporate also something like this for saved UCS's the code reads the current ucs's names.
; Thanks to Gile for the read UCS
; Multi radio by AlanH
(setq named-UCS '("World"))
(vlax-for ucs (vla-get-UserCoordinateSystems
(vla-get-Activedocument
(vlax-get-acad-object)
(setq named-UCS (cons (vla-get-Name ucs) named-UCS))
(setq named-UCS (reverse named-ucs))
(setq named-UCS (cons "Please choose " named-UCS ))
(if (not AH:Butts)(load "Multi radio buttons.lsp"))
(setq ans (ah:butts 1 "V"   named-UCS))
(if (= ans "World")
(command "UCS" ans)
(command "UCS" "R" ans)
Message 5 of 9
hoseobshim
Thank you komondormrex, and apologies for my late response.
I've just learned an acet function and have already started using it.
Message 6 of 9
hoseobshim
Thank you Kent Cooper, and apologies for my late response.
You have greatly helped me to complete my code.
Message 7 of 9
hoseobshim
Thank you Sea-Haven, and apologies for my late response.
It appears your code gives me more info than I need, the variable number of tiles in dcl ! I've just discovered what my next lisp will be.
Message 8 of 9
komondormrex
most generous op. 👍
Message 9 of 9
Sea-Haven
Multi radio buttons
Multi radio buttons 2 col
on to do as many radio but  columns in one code.
Multi getvals
Multi toggles
Just pm with an email and can send the others.
