Lisp to remove the penultimate and antepenultimate vertices of multiple polylines
mikael.macial
Message 1 of 15
mikael.macial
I'd like to create a lisp that removes the 3rd last (antepenultimate) and 2nd last (penultimate) vertices of the selected polylines.
All the polylines have more than 4 vertices, usually 5.
I've tried to use chatgpt to generate some, but none of them worked.
It looks like a simple lisp to create, but i'm not good at codes..
Can you guys help me?
Replies (14)
Message 2 of 15
komondormrex
are plines all-line-segment-ed?
if they are, you may check the code below.
(foreach pline_object (mapcar 'vlax-ename->vla-object
							(vl-remove-if
								'listp
									(mapcar
										'cadr
											(ssnamex (ssget '((0 . "lwpolyline"))))
		(setq last_point (vlax-curve-getendpoint pline_object)
		      last_point (list (car last_point) (cadr last_point))
		      pline_vertices_raw_list (append (reverse (cddr (cddr (cddr (reverse (vlax-get pline_object 'coordinates)))))) last_point)
		(vla-put-coordinates pline_object (vlax-safearray-fill (vlax-make-safearray
										vlax-vbdouble
										(cons 0 (1- (length pline_vertices_raw_list)))
Message 3 of 15
-didier-
Bonjour @mikael.macial
this is a real false good idea, this is false advertising this AI
I’m not sure if @komondormrex 's answer is correct based on the question. Because the last vertex has to stay
You ask to remove the 3rd last (ante penultimate) and 2nd last (penultimate) leaving the last one in place
Then I propose this, the command name is TEST :
(defun removenth (n lst / i rtn);found on the swamp by Jeff_M
    (reverse (progn (setq i -1)
                 (foreach x lst (if (/= n (setq i (1+ i)))(setq rtn (cons x rtn))))
                 rtn)
(defun delpa (ent / coords coords2)
    ;Lisp to remove the penultimate and antepenultimate vertices of multiple polylines
    (if
        (and (>= (cdr (assoc 90 (entget ent))) 4)
             (setq ent (vlax-ename->vla-object ent))
        (progn
            (setq coords (vlax-get ent 'coordinates))
            (setq coords2 coords)
            (setq len (length coords))
            (setq pos (- len 3))
            (repeat 4 (setq coords (removenth (- (length coords)3) coords)))
            (vlax-put ent 'coordinates coords)
        (alert "Bad polyline")
(defun c:test ( / n ss coords ent)
    (setq n -1)
    (setq ss (ssget '((0 . "LWPOLYLINE"))))
    (repeat (sslength ss)
        (setq ent (ssname ss (setq n (1+ n))))
        (delpa ent)
This is a real false good idea, this is false advertising this AI
let me know if that’s right, please
Amicalement
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
Message 4 of 15
mikael.macial
it worked perfectly, exactly how i imagined!
what a fast solution!!
thank you very much!!
about the AI, wasn't my intention to say it doesn't work..
it was I that couldn't make it work for me, certainly because a lack of knowledge of how to ask and to interpretate the code that it generated for me.
thanks again!!
Message 5 of 15
mikael.macial
Sorry, I can't identify the command of this lisp, so wasn't able to test this one..
Message 6 of 15
Kent1Cooper
(defun C:WHAT (/ pl verts)
  (setq pl (car (entsel "\nPolyline to have two vertices prior to last one removed: ")))
  (if (> (setq verts (cdr (assoc 90 (entget pl)))) 3); long enough?
    (progn ; then
      (command "_.pedit" pl "_edit")
      (repeat (- verts 4) (command "_next"))
      (command "_straighten" "_next" "_next" "_next" "_go" "_exit" "")
    ); progn
  ); if
  (prin1)
It checks whether there are enough vertices, but does not check [but could be made to] whether what you picked was a Polyline.  Works only with LWPolylines, but could be enhanced to work on 2D "heavy" and 3D ones [they don't have (assoc 90), so number of vertices has to be calculated differently].  And note that in a closed one, the last vertex is not back at the first one -- if that's what you mean, this won't do, because the Next option under the Edit vertex option won't keep going back to the start.
Kent Cooper, AIA
Message 7 of 15
-didier-
You're welcome, I’m glad to be of service.
It doesn't if the polylines have a bulge, OK ?
Don’t talk to me about chatgpt, I’d like to stay calm.
Amicalement
DA
Message 8 of 15
mikael.macial
ok, thanks again!!
Message 9 of 15
komondormrex
@-didier- surely i missed the point.
@mikael.macial check the update.
Message 10 of 15
mikael.macial
didn't worked..
- started the command and got the message "Polyline to have two vertices prior to last one removed"
- selected the polyline
- got the error "bad argument type: lentityp nil"
the objects that I'm testing are polylines, created with the PLINE command (just to reassure).
Message 11 of 15
mikael.macial
what is the command to start the lisp?
i usually see in the codes a line with "(defun C: 'command to use the lisp' ....
Message 12 of 15
Kent1Cooper
@mikael.macial wrote:
didn't worked..
It worked for me, and I just tried some more, successfully.  Are they LightWeight Polylines?  PLINETYPE System Variable = 1 or 2 when they were drawn?  Properties calls them "Polyline," not "2D Polyline" or "3D Polyline"?  LIST reports them as "LWPOLYLINE"?
But I suspect those are not the problem -- they would not result in the error message you got, which I get if I miss in picking one.
Kent Cooper, AIA
Message 13 of 15
mikael.macial
PLINETYPE System Variable = 1 or 2 when they were drawn? - = 2
Properties calls them "Polyline," not "2D Polyline" or "3D Polyline"? - just "Polyline"
LIST reports them as "LWPOLYLINE"? - Yes
got it to work, probably had pasted it wrong before..
just as a feedback:
- worked as I wanted, but can't select more than one object at the same time (or preferably make a selection box)
- doesn't seems to work if already selected the object before the command
@Anonymous Lisp works great and very clean
but thanks for the help!!
it still works fine and would help me!
glad to see a community so helpful! =]
Message 14 of 15
Kent1Cooper
I could have worked those in originally if you had mentioned them.  Try this [lightly tested]:
(defun C:PLVR (/ ss n pl verts) ; = PolyLine Vertex Removal
  (if (ssget "_I" '((0 . "LWPOLYLINE"))); pre-selection containing Polyline(s)?
    (setq ss (ssget "_:L-I" '((0 . "LWPOLYLINE")))); then [only unlocked ones]
    (progn ; else
      (prompt "\nTo remove two vertices prior to last one(s) from Polyline(s),")
      (setq ss (ssget "_:L" '((0 . "LWPOLYLINE")))); User select
    ); progn
  ); if
  (if ss
    (repeat (setq n (sslength ss))
      (setq pl (ssname ss (setq n (1- n))))
        (progn ; then
        ); progn
      ); if
    ); repeat
    (prompt "\nNo Polylines on unlocked Layers selected."); else
  ); if [selection]
  (prin1)
Kent Cooper, AIA
Message 15 of 15
ronjonp
Another for fun 🙂
(defun c:foo (/ o p s)
  ;; RJP » 2023-05-05
  ;; Remove the 2nd and 3rd to last vertexes of LWPOLYLINES
  (if (setq s (ssget ":L" '((0 . "LWPOLYLINE") (-4 . ">") (90 . 3))))
    (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
      (setq p (reverse (vlax-get (setq o (vlax-ename->vla-object e)) 'coordinates)))
      (vlax-put o 'coordinates (append (reverse (cdddr (cdddr p))) (reverse (mapcar '+ '(0 0) p))))
  (princ)
(vl-load-com)
