autonumbering multileader lisp
muhamed_ragab92
Message 1 of 14
muhamed_ragab92
how can auto numbering for multi leader with find and replace a letter as t count because t count is't worked with multi leader ?
EX, As test plan , find N and auto number from and increment 1
Replies (13)
Message 2 of 14
devitg
@muhamed_ragab92 , as I can get from the test dwg , all mleader have the same textstring
("\\A1;{\\C90; SN/\\A0;\\C3;SERG-PB\\A1;\\C90;\\P 3X4MM2 ,CU/PVC\\P UPVC CONDUIT Ø25MM}"
, and there is no a single N , only a SN, please clear , or better do a "after"  from any one mleader
Message 3 of 14
muhamed_ragab92
I mean , will find the N letter as variable and auto number it ,
the file attached
Message 4 of 14
devitg
As you can see , there is no  a SINGLE N at the mleader text , there are one N at SN , and another at CONDUIT .
as to be possible to change the N by a count , it shall be a ONLY ONE N at the mleader
Message 5 of 14
muhamed_ragab92
Okay i can make N any another variable but you find that list to do it that action
Message 6 of 14
devitg
@muhamed_ragab92 , some like it ?
Message 7 of 14
muhamed_ragab92
yes , that's exactly what i mean it , what is the lisp please? or the script?
Message 8 of 14
calderg1000
Regards @muhamed_ragab92
Try this code, configured for your example drawing.
(defun c:mln ( / n s sn tlead nt n)
  (setq n (getint "\nEnter Start Number:"))
  (while
    (setq s     (car (entsel "\nSelect Mleader:"))
          sn    (entget s)
          tlead (assoc 304 sn)
          nt    (strcat (itoa n) " " (cdr tlead))
          n     (1+ n)
     (entmod (subst (cons 304 nt) tlead sn))
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Message 9 of 14
muhamed_ragab92
this code is just add prefix number with increment but i want auto numbering for variable letter as "N" like t count function with text
AS the attached video
Message 10 of 14
calderg1000
Dear @muhamed_ragab92
Here I made a small change.
(defun c:mln (/ n s sn tlead nt n)
  (while
          sn    (entget s)
          nt    (vl-string-subst (itoa n) "N" (cdr tlead))
          n     (1+ n)
Carlos Calderon G
Message 11 of 14
3wood
You can also try ALTEXT.
Copy the mleader first, then use it to change the number in sequence.
Message 12 of 14
muhamed_ragab92
The issue is the script is related to only for N variable only not any alphatical , and can't select multi leaders once , only one by one
thanks for your help
Message 13 of 14
calderg1000
Please try this code, for multiple selection
(defun c:m_l (/ n s sn tlead nt n)
  (princ "\nSelect Mleader:")
  (setq s  (ssget '((0 . "Multileader")))
        n  (getint "\nEnter Specify starting number (start):")
        tx (getstring "\nPlacement of numbers in text < Find&replace>:")
  (repeat (setq i (sslength s))
    (setq
      sn    (entget (ssname s (setq i (1- i))))
      nt    (vl-string-subst (itoa n) tx (cdr tlead))
      n     (1+ n)
    (princ)
Carlos Calderon G
Message 14 of 14
muhamed_ragab92
thanks bro so much , that's the solution
