I NEED SELECT TEXT, COPY LAST TEXT , DELET LAST TEST, AND IN LEADER....
rolisonfelipe
rolisonfelipe
(defun c:TLXT()
(command "layer" "m" "txt_cota" "c" "1" "" "")
(setq laymo (getvar "clayer"))
(setq osmo (getvar "osmode"))
(setq SS1 (ssget))
(while
(setq DATATEXT (entget (ssname  SS1 ))
(command "_ERASE SS1 "))
(command "_LEADER" pt pause "" "" "m" DATATEXT ""))
(setvar "clayer" laymo)
(setvar "osmode" osmo)
(PRINC))
devitg
test it
(setq SS1 (ssget "_:S+." '( ( 0 . "TEXT")   )))
(while
(setq DATATEXT (cdr (assoc 1 (entget (ssname  SS1 0 )))))
(command "_ERASE" SS1 "")
(setq osmode (getvar 'osmode))
(setvar 'osmode 0)
(command "_LEADER" pause  pause  "" "" "m" DATATEXT "")
);end while
(setvar 'osmode osmode)
rolisonfelipe
THANK YOU, IT'S PERFECT! I WILL TRY ADD TEXT AND MTEXT
