Automatic line generation
ctnycc
ctnycc
Good Day,
I have a spreadsheet with grid coordinates and was wondering if anyone can help with a routine to assist in producing lines for each of these.  An example of the layout in the spreadsheet is attached.   I am using this to highlight onthe map the locations of highway assets.
Any help or suggestions welcome
Thanks in advance
Regards
COlin
ВeekeeCZ
Use don't need routine. Make simple script in excel.
Use this formula
US (comma delimiter)
=CONCATENATE(E2," ",A2,",",B2," ",C2,",",D2," ")
Internetional (semicolon delimiter)
=CONCATENATE(E2;" ";A2;",";B2;" ";C2;",";D2;" ")
The point is get something like this:
LINE x1,y1 x2,y2
LINE x3,y3 x4,y4
...and paste the result column into autocad command line.
ctnycc
Hi BeeKeeCZ, i started looking at the first part using excel, second part looks promising, but i don't want the lines joined up, need to break the line command up after each line.
ВeekeeCZ
I don't think is needed. If you paste whole colomn, then the paragraph mark does that. Otherwise add one more space at the end of formula.
