automatic dimensions between block's base points
Message 1 of 28
I would like to generate automatic dimensions after I placeded my blocks. In the pic there is an example.
The blue blocks's base points are in the middle of them, and I would like to generate automatically the red measures.
I know continoue dimension method, but when I have 300 block, I don't want to clik on every of them.
QDIM simply does not work with block basepoints.
Anyone have a lips for this?
I tried to watch hours long lips makeing tutorials, but I am too noob to understand it.
Thank you!
Replies (27)
Message 21 of 28
thsa2501
hii beekeecz,
thanks a lot for your reply.i learned a lot from you.😍😍😍
bestregards
hussain
Message 22 of 28
nathanmYEGYT
Observer
Observer
The dimension doesn't appear after selecting either horizontal, vertical or aligned.
Am I missing a step?
Message 23 of 28
ВeekeeCZ
Possibly you have DIMLAYER off.
Message 24 of 28
nathanmYEGYT
Observer
Observer
Nope DIMLAYER is on.  Could it be an issue with the block itself?
Message 25 of 28
nathanmYEGYT
Observer
Observer
I have attached the block I'm trying to dimension.
Message 26 of 28
ВeekeeCZ
Seems perfectly fine. Just a scale is a little too small, but that follows your dwg setting.
Message 27 of 28
nathanmYEGYT
Observer
Observer
ok, any other solution as to why the dimensions don't appear after selecting either option.
Message 28 of 28
ВeekeeCZ
What version of ACAD do you use?
COpy-paste the command-line listing.
Possibly make a video of your doing.
