Delete Blocks from multiple drawings
Message 1 of 15
Hi All,
I am looking for a LISP routine that will delete a block from multiple drawings.
I have read other posts about this and cant figure out how people used these LISP routines or scripts in a batch process.
I thought there was a LISP years ago that would do what I am looking for.
Anyone have any suggestions?
Thanks in advance
Replies (14)
Message 2 of 15
Moshe-A
@Anonymous  hi,
here is a command DELBLK to delete a block ("YourBlockName") from a dwg
it steps through all tabs (layouts) and delete only the 'free' blocks (e.g not nested)
to it run through all files use  >> script pro 2 <<
enjoy
Moshe
(defun c:delblk (/ ss)
 (foreach lay (layoutlist)
  (setvar "ctab" lay)
  (if (setq ss (ssget "_x" '((0 . "insert") (2 . "YourBlockName"))))
   (command "._erase" ss "")
  ); if
 ); foreach
 (princ)
Message 3 of 15
Moshe-A, thanks for the quick reply. I should have been more specific, but I am looking for a LISP that removes a block from multiple drawings, NOT multiple layout tabs. Would this LISP work for multiple drawings if I used script Pro 2?
Message 4 of 15
Moshe-A
@Anonymous
Yes
Replace "YourBlockName" with your actual block name.
Message 5 of 15
pbejse
@Anonymous wrote:
Hi All,
(Defun c:DeleteBlockName (/ f filesToProcess  cnt odbx)
  (if
    (and
      (setq f (acet-ui-pickdir
		"Select folder to process"
		(getvar 'dwgprefix)
      (setq filesToProcess (vl-directory-files f "*.dwg" 1))
      (setq blkname (vl-princ-to-string (lisped (if blkname blkname "Enter Block name"))))
      (not (member blkname '("0" "-1")))
      (snvalid blkname)
     (progn
       (if (< (atoi (substr (getvar "ACADVER") 1 2)) 16)
	 (setq odbx (vlax-get-or-create-object "ObjectDBX.AxDbDocument"))
		      (strcat "ObjectDBX.AxDbDocument."
       (foreach	itm filesToProcess
	 (setq cnt 0)
	 (if
	   (not
	     (vl-catch-all-error-p
	       (vl-Catch-All-Apply
		 '(lambda ()
		    (vla-open odbx (setq fullname (strcat f "\\" itm)))
	    (progn
	      (vlax-for	layout (vla-get-layouts odbx)
		(vlax-for objBlock (vla-get-block layout)
		  (if
		    (and
		      (vlax-write-enabled-p objBlock)
		      (= (setq objtype (vla-get-objectname objBlock))
			 "AcDbBlockReference"
		      (eq (strcase
			    (Vlax-get objBlock 'effectivename)
			  blkname
		    (progn
		     (Vla-delete objBlock) (setq cnt (1+ cnt))
	      (if (> cnt 0)
		(progn
	      		(vla-saveas odbx fullname)
		  	(princ (strcat "\n" (vl-filename-base fullname)
				       "\nDeleted " (itoa cnt) " block(s) : " blkname ))))
       (vlax-release-object odbx)
  (princ)
HTh
Message 6 of 15
Pbejse, thank you for the LISP. I'm not sure how to get it to work though. When I load the app in AutoCAD and type the command prompt, it opens up a dialog box to select a folder. I am not sure what I am to do at this point. Is it looking for the folder where the block resides?
Nancy
Message 7 of 15
pbejse
@Anonymous wrote:
.. it opens up a dialog box to select a folder. I am not sure what I am to do at this point. Is it looking for the folder where the block resides?
The program prompts for the folder where the drawing files will be searched for the  block name to be deleted
If successful, you will see something like this on the command prompt
Sample File 1
Deleted 3 block(s) : TargetBlockName
Sample File 2
Deleted 1 block(s) : TargetBlockName
To be on the safe side, back up your files if you're not sure if this program is for you
Message 8 of 15
Thank you pbejse!
Message 9 of 15
pbejse
@Anonymous wrote:
Thank you pbejse!
You are welcome @Anonymous Glad to help.
Message 10 of 15
pbejse, I thought it was working after you explained it, but I'm confused with something. When I load the LISP and I select the folder I want to run the LISP on, I am prompted with a window "Contents" of Edit Mtext window.
Can you tell me what I am to do with that?
Message 11 of 15
pbejse
That is where you type the name of the block to deleted inside the drawing within the selected folder
Its an alternative for prompting the user to type in the command prompt.
(setq blkname (getstring "\nEnter Block name: " T))
(snvalid blkname)
Command: Enter Block name:
I personally dont like typed-in values.
Preferably the drawing where you invoke command will have the block that you want to delete, that way the program can prompt the user to select on a listbox instead of typing the name, which at times the user is not even sure of the of the spelling <--- really really
Will that work for you?
Message 12 of 15
pbejse, sorry, I cannot get this to work.
This is what I am doing:
1. I have all the drawings in one folder, located on my desktop.
2. I open one drawing and "APPLOAD" the LISP.
3. I type the command prompt "deleteblockname"
4. I browse to the folder where my drawings reside (on desktop), then hit OK
5. I am prompted to enter text in the "Edit Mtext" window. I type the name of the block I want to delete.
In this case, the block name is "Seal Fant TX", then hit OK
Nothing happens at this point. The command window shows "Command" as if it were ready for another command.  I look at the drawings in the folder and the block is still there.
Do you know what this could possibly be?
Message 13 of 15
pbejse
[ update ]
This is whats missing
(snvalid (setq blkname (strcase blkname)))
Truly my bad 🙂
Glad it works for you now.
Cheers
Message 14 of 15
adiez_ife
where will i insert this line?
Message 15 of 15
Sea-Haven
Look at post 5.
