Automatic dimension
Automatic dimension
larsr2866
Message 1 of 61
Automatic dimension
larsr2866
Hello everyone,
I did a bit of searching on this forum for automatic dimensions. I have found some interesting tips for automatic dimensions with selecting rectangles, but i'd try something else.
I made a screenshot for what i want to achieve. I want to automatically create 2 dimensions between the first lines/polylines/objects/... where i am clicking in.
I hope it's clear on the screenshot i took ? (the red circle is the position i click, and at that position i would have a vertical en horizontal dimension between the first lines/plines.)
I don't know if there are options for this?
Thanks in advance.
Lars
Replies (60)
Message 41 of 61
sajansainju73
Community Visitor
Community Visitor
Please find the attached sample drawing.
Message 42 of 61
Kent1Cooper
That's a different kind of Dimensioning, but in any case the same idea has come up before.  See, for example, the DPI and DPO commands in DimPoly.lsp >here<.  If you define a Dimension Style with both extension lines and both dimension lines suppressed, it can look like your image.  The distance of the text part from the Polyline can be changed [see Message 47 there].
Kent Cooper, AIA
Message 43 of 61
marko_ribar
Here is the topic you could find useful...
https://forums.augi.com/showthread.php?168619-Automatically-dimension-all-sides-and-angles-of-select...
HTH.
M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 44 of 61
17ngo01ni84
this looks great but can it be modified to pick circle centres and not edges
Message 45 of 61
hak_vz
It can be done, but it's completely different algorithm. Start new request (new post), attach sample drawing and give thorough explanation. You can call me to participate in finding solution. This post is already way to long.
Miljenko Hatlak
Message 46 of 61
rolisonfelipe
FIRST, CONGRATULATIONS ON THE EXCELLENT SOLUTION.
I WOULD LIKE TO KNOW IF YOU COULD CREATE A VERSION WITH THE FOLLOWING OPTIONS.
1) SELECT OBJECTS, OR SELECT ALL ON THE COMMAND LINE
(initget 0 "ALL or Select")
(setq sel (getkword "\nSet selection system All / Select"))
(condition
((= sel "All")
(setq ss (ssget "_X" '((0 . "LWPOLYLINE,LINE,CIRCLE,ELLIPSE"))))
((= sel "Selectl")
(setq ss (ssget '((0 . "LWPOLYLINE,LINE,CIRCLE,ELLIPSE"))))
2) BE ABLE TO CONTINUE QUOTING IF NEEDED TO SELECT AGAIN, AND BE ABLE TO SWITCH BETWEEN "H V B" ON THE COMMAND LINE
(setq sel (getkword "\nDraw Horizontal, Vertical or Both dimensions <H V B> ?"))
MY BEST REGARDS
Message 47 of 61
hak_vz
@rolisonfelipe I'm currently flooded with work, so I'll work on your request during the weekend.
Miljenko Hatlak
Message 48 of 61
rolisonfelipe
Thank you very much, and a great job!
I will stay
Message 49 of 61
hak_vz
@rolisonfelipe  try this for a start, I'll make new version when I fine dome spare time.
(defun c:dimhorver_RF
	;author hak_vz
	;https://forums.autodesk.com/t5/user/viewprofilepage/user-id/5530556
	;Satuerday, May 18, 2024
	/ *error* mappend mklist flatten take pointlist3d sset->enameList get_intersections get_intersection_points
	adoc ss enameList pt line_hor line_hor_obj line_ver line_ver_obj i j ph pv eo int_pts sel old_dim_assoc st
	(defun *error* ( msg )
		(if (not (member msg '("Function cancelled" "quit / exit abort")))
			(princ)
		(if (and adoc) (vla-endundomark adoc))
		(setvar 'cmdecho 1)
		(setvar 'DIMASSOC old_dim_assoc)
		(princ)
	(defun take (amount lst / ret)(repeat amount (setq ret (cons (car lst) (take (1- amount) (cdr lst))))))
	(defun pointlist3d (lst / ret) (while lst (setq	ret (cons (take 3 lst) ret) lst (cdddr lst))) (reverse ret))
	(defun mappend (fn lst)(apply 'append (mapcar fn lst)))
	(defun mklist (x) (if (listp x) x (list x)))
	(defun flatten (exp)(mappend 'mklist exp))
	(defun sset->enameList (ss / i ret)
		; extracts elements name for all objects in a selection set into a list
		(if ss
			(repeat (setq i (sslength ss))
				(setq ret (cons (ssname ss (setq i (1- i))) ret))
			) ;_ end of repeat
		) ;_ end of if
	) ;_ end of defun
	(defun get_intersections	(obj1 obj2 / var)
		(setq var (vlax-variant-value (vla-intersectwith obj1 obj2 1)))
		(if (< 0 (vlax-safearray-get-u-bound var 1))(vlax-safearray->list var))
	(defun get_intersection_points (obj1 obj2) (pointlist3d (get_intersections obj1 obj2)))
	(setq adoc (vla-get-activedocument (vlax-get-acad-object)))
	(setq old_dim_assoc (getvar 'DIMASSOC))
	(setvar 'DIMASSOC 1)
	(setvar 'cmdecho 0)
	(setq i 1)
	(while
			(if (= i 1)
				(progn
					(initget 1 "A S Q")
					(setq st (strcase(getkword "\nSelect all <A> make selection <S> or quit <Q>  <A/S/Q>: ")))
				(progn
					(initget 1 "A S P Q")
					(setq st (strcase(getkword "\nSelect all <A> make selection <S>  previous <P> or quit <Q>  <A/S/P/Q>: ")))
			(setq i (1+ i))
		(cond
			((= st "A")(setq ss (ssget "_X" '((0 . "LWPOLYLINE,LINE,CIRCLE,ELLIPSE")))))
			((= st "S")(setq ss (ssget '((0 . "LWPOLYLINE,LINE,CIRCLE,ELLIPSE")))))
			((= st "P")(if ss (setq ss ss) (setq ss nil)))
			((T (setq ss nil)))
	    (cond
			((and(and ss) (> (sslength ss) 0))
				(setq enameList (sset->enameList ss))
				(initget 1 "H V B")
				(cond
					((= sel "H")
						(setq pt (getpoint "\nPick a point for horizontal dimensions position >"))
					((= sel "V")
						(setq pt (getpoint "\nPick a point for vertical dimensions position >"))
					((= sel "B")
						(setq ph (getpoint "\nPick a point for horizontal dimensions position >"))
						(setq pv (getpoint "\nPick a point for vertical dimensions position >"))
						(setq pt (list (car pv) (cadr ph)))
				(cond
					((and pt)
						(vla-startundomark adoc)
						(setq line_ver
							(entmakex
								(list
									(cons 0 "XLINE")
									(cons 100 "AcDbEntity")
									(cons 100 "AcDbXline")
									(cons 10 (trans pt 1 0))
									(cons 11 '(0 1 0))
						(setq line_ver_obj (vlax-ename->vla-object line_ver))
						(setq line_hor
							(entmakex
								(list
									(cons 0 "XLINE")
									(cons 11 '(1 0 0))
						(setq line_hor_obj (vlax-ename->vla-object line_hor))
						(cond
							((or (= sel "H")(= sel "B"))
								(setq i -1)
								(while (< (setq i (1+ i)) (length enameList))
									(setq eo (vlax-ename->vla-object (nth i enameList)))
									(setq ipts (get_intersection_points line_hor_obj eo))
									(if (and ipts) (setq int_pts (cons ipts int_pts)))
								(cond
									((and int_pts)
										(setq int_pts (vl-sort (flatten int_pts) '(lambda (x y) (< (car x)(car y)))))
										(setq j -1)
										(while (< (setq j (1+ j)) (1- (length int_pts)))
											(command "_.dimhorizontal" (nth j int_pts)(nth (1+ j) int_pts)(nth (1+ j) int_pts))
								(setq int_pts nil)
						(cond
							((or (= sel "V")(= sel "B"))
								(setq i -1)
									(setq ipts (get_intersection_points line_ver_obj eo))
								(cond
									((and int_pts)
										(setq int_pts (vl-sort (flatten int_pts) '(lambda (x y) (< (cadr x)(cadr y)))))
										(setq j -1)
											(command "_.dimvertical" (nth j int_pts)(nth (1+ j) int_pts)(nth (1+ j) int_pts))
								(setq int_pts nil)
						(if (and eo)(vlax-release-object eo))
						(if (and line_hor_obj)(vlax-release-object line_hor_obj))
						(if (and line_ver_obj)(vlax-release-object line_ver_obj))
						(entdel line_hor)
						(entdel line_ver)
			((T nil))
(*error*)
(princ "\nDone!")
(princ)
Miljenko Hatlak
Message 50 of 61
17ngo01ni84
How can we have this pick hole centres and not diameters?
Message 51 of 61
hak_vz
@17ngo01ni84  Start a new post (request), describe what you need and attach sample drawing. This code use intersection with objects and doesn0 take its properties (i.em circle center). I could modify my code but need some sample drawing for guidance. So, start new post!
Miljenko Hatlak
Message 52 of 61
17ngo01ni84
dimensioning as below
Sample as below
Message 53 of 61
Kent1Cooper
QDIM will do pretty much exactly that.
[If by "sample" you meant to attach a drawing file, it didn't attach.  If you were trying by replying to an email notice that someone replied to your earlier one, you can't attach things that way.  You must come to the website in a "real" browser.]
Kent Cooper, AIA
Message 54 of 61
17ngo01ni84
I understand but Qdim is slow. I will have hundreds of these objects that need dimensioning and comes in different sizes. When i use QDIM, i then need to delete all the dimensions between these objects as I only need dimensions to appear on the individual object and not between them. This is quite time consuming. This LISP works perfectly for what I want but I need it to pick distances between centres. That's the only enhancement that I need.
Message 55 of 61
Kent1Cooper
Getting back to the procedure in the original Message:  Are you talking about picking at one spot inside an outline that has some Circles inside it, and getting Dimensions as in your image, not just the overalls as in the original?  Or is it your intent to select all the Circles and the outline parts?  Or something else?
Kent Cooper, AIA
Message 56 of 61
17ngo01ni84
I need to dimension from the outline, passes through hole centres and ends at the the other side
my desired result is as below
Message 57 of 61
Kent1Cooper
That doesn't fully answer my question.  Supposing a custom command, you would call the command name, and then you would expect to....
Select all the Circles and the whole box around them, all together?  Or only one direction's worth at a time?  Select the Circles only, and somehow use the functionality from earlier routines in this topic to find the boundary Lines?  Just pick inside the box and have the routine find the Circles?  How would the position of the dimension lines be determined -- by User pick or somehow calculated by the routine?  Etc., etc.
Kent Cooper, AIA
Message 58 of 61
marko_ribar
I coded something for circles and recorded video... It is connected with your example shown at picture...
(defun c:qdimcents ( / *error* foo cmd osm bp ch chh )
  (or (not (vl-catch-all-error-p (vl-catch-all-apply (function vlax-get-acad-object) nil))) (vl-load-com))
  (defun *error* ( m )
    (while (= 8 (logand 8 (getvar (quote undoctl))))
      (if command-s
        (command-s "_.undo" "_e")
        (vl-cmdf "_.undo" "_e")
    (if osm
      (setvar (quote osmode) osm)
    (if cmd
      (setvar (quote cmdecho) cmd)
    (if m
      (prompt m)
    (princ)
  (defun foo ( mode bp ch / p xl s ss entlst pl plst pll )
    (vl-cmdf "_.xline" bp (if (= mode 1) (polar bp 0.0 1.0) (polar bp (* 0.5 pi) 1.0)))
    (while (< 0 (getvar (quote cmdactive)))
      (vl-cmdf "")
    (setq xl (entlast))
    (if (setq s (ssget "_A" (list (cons 0 "*POLYLINE,LINE"))))
      (cond
        ( (vl-every (function (lambda ( x ) (= (cdr (assoc 0 (entget x))) "LINE"))) (setq entlst (mapcar (function cadr) (ssnamex s))))
          (foreach ent entlst
            (if (setq p (vlax-invoke (vlax-ename->vla-object xl) (quote intersectwith) (vlax-ename->vla-object ent) acextendnone))
              (if (= (length p) 3)
                (setq pl (cons p pl))
        ( (vl-every (function (lambda ( x ) (wcmatch (cdr (assoc 0 (entget x))) "*POLYLINE"))) (setq entlst (mapcar (function cadr) (ssnamex s))))
          (foreach ent entlst
              (if (= (length p) 6)
                (setq pl (cons (list (car p) (cadr p) (caddr p)) pl) pl (cons (list (nth 3 p) (nth 4 p) (nth 5 p)) pl))
    (setq pl (mapcar (function (lambda ( p ) (trans p 0 1))) pl))
    (setq pl (vl-sort pl (function (lambda ( a b ) (< (if (= mode 1) (car a) (cadr a)) (if (= mode 1) (car b) (cadr b)))))))
    (if (setq ss (ssget "_A" (list (cons 0 "CIRCLE"))))
      (progn
        (setq entlst (mapcar (function cadr) (ssnamex ss)))
        (setq plst (mapcar (function (lambda ( x ) (trans (cdr (assoc 10 (entget x))) 0 1))) entlst))
        (setq plst (vl-remove-if (function (lambda ( x ) ((if (= ch "UpperRight") < >) (if (= mode 1) (cadr x) (car x)) (if (= mode 1) (cadr bp) (car bp))))) plst))
        (setq plst (vl-sort plst (function (lambda ( a b ) (< (if (= mode 1) (car a) (cadr a)) (if (= mode 1) (car b) (cadr b)))))))
        (setq plst (vl-remove-if-not (function (lambda ( x ) (< (if (= mode 1) (caar pl) (cadar pl)) (if (= mode 1) (car x) (cadr x)) (if (= mode 1) (caadr pl) (cadadr pl))))) plst))
        (setq plst (mapcar (function (lambda ( x ) (list (if (= mode 1) (car x) (car bp)) (if (= mode 1) (cadr bp) (cadr x)) 0.0))) plst))
        (setq pl (append (list (car pl)) plst (list (cadr pl))))
        (if (and xl (not (vlax-erased-p xl)))
          (entdel xl)
        (setq pll (mapcar (function (lambda ( a b ) (list a b))) pl (cdr pl)))
        (foreach pp pll
          (vl-cmdf "_.dimlinear" (car pp) (cadr pp) (polar (polar (car pp) (angle (car pp) (cadr pp)) (/ (distance (car pp) (cadr pp)) 2.0)) (+ (angle (car pp) (cadr pp)) (* 0.5 pi)) (getvar (quote dimasz))))
            (vl-cmdf "")
  (setq cmd (getvar (quote cmdecho)))
  (setvar (quote cmdecho) 0)
  (setq osm (getvar (quote osmode)))
  (setvar (quote osmode) 0)
  (setvar (quote textsize) (* 2.0 (getvar (quote dimasz))))
  (vl-cmdf "_.undo" "_be")
  (initget 1 "UpperRight LowerLeft")
  (setq ch (getkword "\nChoose option [UpperRight/LowerLeft] : "))
  (initget "X Y Both")
  (setq chh (cond ( (getkword "\nDo you want dimensioning parallel with axises [X/Y/Both]  : ") ) ( "Both" )))
  (initget 1)
  (setq bp (getpoint "\nPick or specify point : "))
  (cond
    ( (= chh "Both")
      (foo 1 bp ch)
      (foo 2 bp ch)
    ( (= chh "X")
      (foo 1 bp ch)
    ( (= chh "Y")
      (foo 2 bp ch)
  (*error* nil)
HTH.
M.R.
Message 59 of 61
17ngo01ni84
You re the BEST!!!
Message 60 of 61
17ngo01ni84
@Kent1Cooper look at the solution from @marko_ribar . That's all i wanted
