Automatic dimension
Automatic dimension
larsr2866
Message 1 of 61
Automatic dimension
larsr2866
Hello everyone,
I did a bit of searching on this forum for automatic dimensions. I have found some interesting tips for automatic dimensions with selecting rectangles, but i'd try something else.
I made a screenshot for what i want to achieve. I want to automatically create 2 dimensions between the first lines/polylines/objects/... where i am clicking in.
I hope it's clear on the screenshot i took ? (the red circle is the position i click, and at that position i would have a vertical en horizontal dimension between the first lines/plines.)
I don't know if there are options for this?
Thanks in advance.
Lars
Replies (60)
Message 61 of 61
marko_ribar
I finally updated my posted code... I made it shorter by adding (foo) sub function and added one new choice (dimensioning parallel to X axis, to Y axis, or both)... Also dimensioning should work as desired in rotated UCS...
The code is on previous page : https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/automatic-dimension/m-p/12789190/hig...
Thanks for attention...
Marko Ribar, d.i.a. (graduated engineer of architecture)
