Visual LISP, AutoLISP and General Customization
Automated checking data
6 REPLIES 6
qasim_talal
311 Views, 6 Replies
Hi
is there a way to check data in AutoCAD drawings, such as an automated (not manually) check of available coordinates with what is drawn in addition to the dimension and area, or check the available coordinates with other apps like Excel file?
or in general is there an automated check in AutoCAD ?
I really appreciate any help you can provide.
Labels (1)
6 REPLIES 6
Moshe-A
in reply to: qasim_talal
@qasim_talal hi,
in AutoCAD there are numbers of tools to help you do that:
Attributes blocks
parametric text fields
DataExtraction
you need to explore each of this tools.
Moshe
Sea-Haven
Looking at the image a hard task as you have points/text and leader text. An idea, label the points in sequence with a starting number, walk along the pline press enter if label ok any key for a leader. Make the table or mtext as you add points. Need a sub option for a branch.
Maybe when labelling add a point block with corner number on a different layer, turn off when plotting. Can walk along a pline etc getting pt number and co-ords.
pbejse
@qasim_talal wrote:
...check of available coordinates with what is drawn..
Is that right after an object is drawn? or ALL existing objects on Model Space? You have to be more specific @qasim_talal
qasim_talal
in reply to: Moshe-A
thanks
i will try them
qasim_talal
in reply to: pbejse
it is in model space but will change if it is drawn?
qasim_talal
in reply to: pbejse
yes, check of available coordinates with what is drawn is there a way you recommend?
Forma Design Contest
AutoCAD Beta
