You can do this in .NET or Python
I have wrapped Sheet sets in Python https://github.com/CEXT-Dan/PyRx Or https://pypi.org/project/cad-pyrx/
If you are able to run this project in your version of AutoCAD, then you can use openpyxl to read and write excel
There may be dragons! I only wrapped Sheet sets and have written a few tests based off
https://adndevblog.typepad.com/autocad/2013/09/using-sheetset-manager-api-in-vbnet.html
I don’t know how to use the Sheet set API beyond the blog sample, so using this will require you to grind through crumbs of samples you find on the internet.
Here is a proof of concept
import traceback
from pyrx_imp import Rx, Ge, Gi, Db, Ap, Ed, Ax, Sm
import openpyxl
from pathlib import Path
@Ap.Command()
def doit():
try:
# open xl
xlwb = openpyxl.load_workbook("E:\\SheetSet.xlsx")
xlsheet = xlwb.active
name = xlsheet.cell(row=1, column=1).value
descrption = xlsheet.cell(row=1, column=2).value
title = xlsheet.cell(row=1, column=3).value
number = xlsheet.cell(row=1, column=4).value
# sheetset
path = "E:\\temp"
fullpath = "E:\\temp\\CP318-5.dst"
dwtfullpath = "E:\\temp\\CP318-5.dwt"
mgr = Sm.SheetSetMgr()
ssdb = mgr.createDatabase(fullpath)
ssdb.lockDb()
setSheetSetDefaults(ssdb, "CP318-5", "Demo", path, dwtfullpath, "Sheet", False)
addSheet(ssdb, name, descrption, title, number)
except Exception as err:
traceback.print_exception(err)
finally:
ssdb.unlockDb(True)
def setSheetSetDefaults(
sheetSetDatabase: Sm.SmDatabase,
description: str,
newSheetLocation: str,
newSheetDWTLocation: str,
newSheetDWTLayout: str,
promptForDWT: bool,
sheetSet = sheetSetDatabase.getSheetSet()
sheetSet.setName(name)
sheetSet.setDesc(description)
if len(newSheetLocation) == 0:
newSheetLocation = str(Path(sheetSetDatabase.getFileName()).parent)
fileReference = sheetSet.getNewSheetLocation()
fileReference.setFileName(newSheetLocation)
sheetSet.setNewSheetLocation(fileReference)
if len(newSheetDWTLocation) != 0:
layoutReference = sheetSet.getDefDwtLayout()
layoutReference.setFileName(newSheetDWTLocation)
layoutReference.setName(newSheetDWTLayout)
sheetSet.setDefDwtLayout(layoutReference)
sheetSet.setPromptForDwt(promptForDWT)
def addSheet(component: Sm.Component, name: str, description: str, title: str, number: str):
sheet = None
if component.getTypeName() == Sm.Subset.className():
subset = Sm.Subset.cast(component)
sheet = subset.addNewSheet(name, description)
else:
smdb = component.getDatabase()
ss = smdb.getSheetSet()
sheet = ss.addNewSheet(name, description)
ss.insertComponentFirst(sheet)
sheet.setNumber(number)
sheet.setTitle(title)
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
