Text style that isn't use and cannot be purged
Brian.TsaiF883G
Message 1 of 17
Brian.TsaiF883G
The attached file is what I am able to isolate as the problem
everything says that I only have have 'standard' text style
when it is in table, the cell states it is 'Standard' text style
after purging, auditing, and scalelistedit reset, it still has the 2 text styles
i can achieve only 'standard' text style by either
a) i explode the table into lines and MText and proceed with above,
b) manually edit new text in Table cell
the 'find' and replace function does not delete the non'standard' text style
any reason the attached file text is special?
I am trying to make a lisp that would get rid these special text's text style and set it to 'standard' text style
Replies (16)
Message 2 of 17
Sea-Haven
 I just did a purge and the 2nd text style was there and its gone now.
Message 3 of 17
Brian.TsaiF883G
I'm using Product Version: Q 47.0.0 AutoCAD 2020 and it failed
Product Version: Q 51.0.0 AutoCAD 2022 and it failed
what version are you using?
Message 4 of 17
Sea-Haven
Bricscad V25. A sometimes add a text using other style then erase and try purge again.
Message 5 of 17
paullimapa
These are the steps I took to manually remove & then purge Style:
 RHIO-1020-ME-PAD-0005.02.IFC.02.01_PDS$0$CSI TITLE BLOCK
First the Purge command confirms that style is Non-Purgeable & in use inside a Table:
Next I use the TABLEDIT command & selected the Cell then immediately clicked a point outside the Table to conclude the command without changing anything.
Now when I enter the PURGE command that style is purgeable:
Paul Li
IT Specialist
@The Office
Message 6 of 17
Brian.TsaiF883G
thanks that works
but i have many many of these cases randomly in random tables and in a random files
What i don't understand is, why is it happening when the properties states it is 'Standard' text style and why we have to go through 'Tabledit' to 'refresh' it?
is there a lisp/ reasoning the text style is unpurgable without 'Tabledit' first?
Message 7 of 17
paullimapa
This may give you a hint on how to do this on a mass selection set:
There's a routine written by Tharwat here called Test.lsp:
https://www.cadtutor.net/forum/topic/63542-table-cell-style-via-lisp/
(defun c:Test ( / sty tbl obj row col r c)
 ;;	Tharwat - Date:  11.Jul.2017	;;
; (setq sty "Standard") ;; Change the Text Style to suit your desired one.
 (setq sty "Arial") ;; Change the Text Style to suit your desired one.
 (if (and (or (tblsearch "STYLE" sty)
            (alert (strcat "Text style <" sty "> is not found in drawing <!>"))
        (princ "\nPick on Table :")
        (setq tbl (ssget "_+.:S:E:L" '((0 . "ACAD_TABLE"))))
        (setq obj (vlax-ename->vla-object (ssname tbl 0))
              row (vla-get-rows obj)
              col (vla-get-columns obj)
              r 0 c 0
   (repeat row
     (repeat col
       (vla-setcelltextstyle obj r c sty) (setq c (1+ c))
     (setq r (1+ r) c 0)
 (princ)
 It allows you to select one Table object to change the Text Style in all the cells.
So what I did was first created a new Style called Arial using Arial.ttf font.
Then I ran the Test.lsp function to change the selected Table cell Style to Arial.
Then I'm able to Purge the problem Style.
Then I edited Test.lsp function to change the selected Table cell Style back to Standard.
After that I Purge the Arial Text Style.
Paul Li
IT Specialist
@The Office
Message 8 of 17
cadffm
because it wasn't the challange to change styles in tables, you can use this "UpdateTables" command, what does not change the table.
(you have to manage layer locking on your own)
; updated code
(defun c:UpdateTables ( / tbls)
   (if (setq n -1 tbls (ssget "_X" '((0 . "ACAD_TABLE"))))
       (repeat (sslength tbls)
         (entmod (entget(ssname tbls (setq n (1+ n)))))
 (princ)
Sebastian
Message 9 of 17
pendean
Community Legend
Community Legend
@Brian.TsaiF883G Do you folks not implement and use CHECKSTANDARDS tools? You create a standards template file to address these non-standards types of issues then run it.
Message 10 of 17
paullimapa
excellent routine to fix the problem!!!
Paul Li
IT Specialist
@The Office
Message 11 of 17
Brian.TsaiF883G
Many thanks.
I didn't know about CHECKSTANDARDS
I tried CHECKSTANDARDS and now i have problem fixing many many dimensions one by one
I tried the Batch Standard Checker and it only generates a report without fixing them
I tried to reprogram the code below but failed to get it to update all tables in all block references
can anyone point out which part in the code below need fixing?
(defun c:BUT ( / tbls blkname blklist ent)
  (while (setq blkname (cdadr (tblnext "block" (not blkname))))
    (if
      (not
        (or
          (wcmatch blkname "`*D*,*|*"); Dimension or Xref-dependent
          (assoc 1 (tblsearch "block" blkname)); an Xref
          (member blkname blklist); already in the list
        ); or
      ); not
      (setq blklist (cons blkname blklist))
    ); if
  ); while
  (foreach blkname blklist
    (setq ent (tblobjname "block" blkname))
    (while (setq ent (entnext ent))
(if (wcmatch (cdr (assoc 0 (setq edata (entget ent)))) "ACAD_TABLE")
; (if (setq n -1 tbls (ssget "_X" '((0 . "ACAD_TABLE"))))
;      (repeat (sslength tbls)
    ); while
  ); foreach
 (princ)
Message 12 of 17
cadffm
Untested.
at the end you are using
what doesn't make any sense, replace it with
(entmod edata)
try it again.
I didn't searched for other issues
Sebastian
Message 13 of 17
Brian.TsaiF883G
It works!
Many thanks 🙂
Message 14 of 17
Brian.TsaiF883G
I have a new case with the same problem but this time, it is on a leader entity with no text at all
Is there any reason this leader entity is so special?
Message 15 of 17
Sea-Haven
Just a guess its buried away in side your table style some how. Do you start drafting with a DWT or pick an existing dwg ? You may need a "Clean" dwg to start with. What happens if you use a good dwg and erase everything in Model & layouts.
There is a message about the style being referenced. I know for another project with errors on load it took hours to find a style in dwg objects.
Message 16 of 17
Brian.TsaiF883G
True
But I'm dealing with various drawings at the moment so there are many inconsistencies in random files.
So now I am trying to 'controlled clean' up all so that will not affect intentional formatting/information in the drawing.
Does anyone know why leader entity have embedded text style?
Message 17 of 17
cadffm
>>"Does anyone know why leader entity have embedded text style?"
EDITED: Why THIS leader entity refers to a Style: I don't know it. Because someone changed the arrowhead, in this case the text style will linked as override to the leader object.
But I'm not so good with LEADER objects either, they're really cool if you don't just use the ootb editing tools.
It's new for me in Acad that DSTYLE  informations contains a Style-1005
Perhaps generated from the Pro Stahl 3D Application?
Sebastian
