AutoLisp Function wd_ss2_import_curdwg Not Working
david.faunce
david.faunce
I'm Using AutoCAD Electrical 2017
In my active drawing I went to "Import/Export Data" -> "To Spreadsheet"
I modified a block's text in the "comp" tab -> Saved
On the command line I entered the following:
(c:wd_ss2_import_curdwg "C:\Users\Documents\testData.xls" 1 1)
Nothing happened, not even an error
I also tried the following:
(c:wd_ss2_import_curdwg "C:\Users\Documents\testData.xls" "1" 1)
(c:wd_ss2_import_curdwg "C:\Users\Documents\testData.xls" "1" "1")
(c:wd_ss2_import_curdwg "C:\Users\Documents\testData" 1 1)
(c:wd_ss2_import_curdwg "C:\Users\Documents\testData" "1" 1)
(c:wd_ss2_import_curdwg "C:\Users\Documents\testData" "1" "1")
Still nothing.
Then I checked to see if my spreadsheet was corrupted, so i went to "Import/Export Data" -> "From Spreadsheet" and loaded the spreadsheet.
It worked perfectly...but only if I manually did it.
This shows that something is wrong with my function (or AutoCAD has some bugs).
Can anyone help??
john.uhden
I don't have Electrical 2017 or anything 2017, but I wonder...
Is c:wd_ss2_import_curdwg really an AutoLisp command function?
Is that what the menu item "Import/Export Data" -> "From Spreadsheet" calls?
Are there other arguments provided in the menu item?  C: functions are usually (in fact almost always) not written to take/require arguments.
Might it actually be wd_ss2_import_curdwg, wherein you should use (command "wd_ss2_import_curdwg" etc.)?
Might the command need to be preceded with (initdia)?
I wish I actually knew the solution, but alas I can only guess.
I doubt that your symptoms are the result of an AutoCAD bug.
John F. Uhden
