Get Attrbute and coordinates from block and creat Table
C.Utzinger
Message 1 of 14
C.Utzinger
HI
I have the attached Block and I was trying to modify the following code to extract the one Attribute, get the coordinates and create a table.
(defun c:<Test7 (/ *error* :sortlst acapp acol acsp adoc atable attdata attitem atts blkdata blkname blkobj col
                   column colwidth datalist en headers pt row ss swap  tabledata tags total txtheight widths x)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (command-s "_.UCS" "_P")
    (princ))
  ;; Lee Mac
  ;; http://www.lee-mac.com/attributefunctions.html
  (defun LM:vl-getattributes ( blk )
    (mapcar '(lambda (att) (cons (vla-get-tagstring att) (vla-get-textstring att)))
            (vlax-invoke blk 'getattributes)))
  ;; ObjectID  -  Lee Mac
  ;; Returns a string containing the ObjectID of a supplied VLA-Object
  ;; Compatible with 32-bit & 64-bit systems
  (defun LM:objectid ( obj )
    (eval (list 'defun 'LM:objectid '(obj)
                (if (and (wcmatch (getenv "PROCESSOR_ARCHITECTURE") "*64*")
                         (vlax-method-applicable-p (vla-get-utility (LM:acdoc)) 'getobjectidstring))
                  (list 'vla-getobjectidstring (vla-get-utility (LM:acdoc)) 'obj ':vlax-false)
                  '(itoa (vla-get-objectid obj)))))
    (LM:objectid obj))
  ;; Active Document  -  Lee Mac
  ;; Returns the VLA Active Document Object
  (defun LM:acdoc nil
    (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
    (LM:acdoc))
  (command "_.UCS" "_W")
  (setq flt "SPI-Datenextraktionspunkt-CM*")
  (if (setq ss (ssget (list '(0 . "INSERT") (cons 2 flt) '(66 . 1))))
    (progn
      (repeat (setq i (sslength ss))
        (setq obj (vlax-ename->vla-object (ssname ss (setq i (1- i))))
              tabledata (cons (LM:vl-getattributes obj) tabledata)))
      (setq tabledata (vl-remove nil tabledata)
            headers (mapcar 'car (car tabledata))
            tags    headers
            tabledata (mapcar '(lambda (x) (mapcar 'cdr x))
                              tabledata))
      ;; sort by "A1" :
      (setq tabledata (vl-sort tabledata '(lambda (a b)(< (car a)(car b)))))
      (if (= tabledata nil)(progn (alert "Keine Daten gefunden!")(exit)))
      (setq total 0)
      (foreach i datalist (setq total (+ total (cdr i))))
      (setq txtheight (if (= btog10 1)(* 15 0.01) 15))
      (or adoc (setq adoc (vla-get-activedocument (setq acapp (vlax-get-acad-object)))))
      (or acsp (setq acsp (vla-get-block (vla-get-activelayout adoc))))
      (setq acCol (vla-GetInterfaceObject acapp(strcat "AutoCAD.AcCmColor." (itoa (atoi (getvar "acadver"))))))
      (setq pt (getpoint (strcat "\n" Typ. " Tabelle einfügen:"))
            atable (vla-addtable
                     acsp
                     (vlax-3d-point pt)
                     (+ 2 (length tabledata))
                     (length headers)
                     (* txtheight 1.2)
                     (* txtheight 20)))
      (vla-put-regeneratetablesuppressed atable :vlax-true)
      ;; calculate column widths :
      (setq swap (append (list headers) tabledata)
            widths nil)
      (while (car swap)
        (setq column (mapcar 'car swap)
              colwidth (* 1.2 (apply 'max (mapcar 'strlen column)) txtheight)
              widths (cons colwidth widths)
              swap (mapcar 'cdr swap)))
      (setq widths (reverse widths))
      ;; set column widths
      (setq col 0)
      (foreach wid widths
        (vla-setcolumnwidth atable col wid)
        (setq col (1+ col)))
      (vla-put-colorindex acCol 8)
      (vla-setgridcolor atable 61 7 acCol)
      (vla-put-horzcellmargin atable (* txtheight 0.5))
      (vla-put-vertcellmargin atable (* txtheight 0.3))
      (vla-setTextheight atable 1 (* txtheight 0.8))
      (vla-setTextheight atable 2 (* txtheight 1.2))
      (vla-setTextheight atable 4 (* txtheight 0.9))
      (vla-setText atable 0 0 "Koordinaten")
      (vla-SetCellAlignment atable 0 0 acMiddleCenter)
      (vla-put-colorindex acCol 3)
      (vla-setcellcontentcolor atable 0 0 acCol)
      (setq col -1)
      (foreach descr headers
        (vla-SetTextStyle atable (+ acHeaderRow acDataRow acTitleRow) "Simplex7-12.5")
        (vla-setText atable 1 (setq col (1+ col)) descr)
        (vla-SetCellAlignment atable 1 col acMiddleCenter)
        (vla-setcellcontentcolor atable 1 col acCol))
      (vla-put-colorindex acCol 4)
      (setq row 2)
      (foreach record tabledata
        (setq col 0)
        (foreach item record
          (vla-setText atable row col item)
          (if (= 1 col)
            (vla-SetCellAlignment atable row col acMiddleCenter)
            (vla-SetCellAlignment atable row col acMiddleCenter))
          (vla-setcellcontentcolor atable row col acCol)
        (setq row (1+ row)))
      (vla-put-width atable (apply '+ widths))
      (vla-put-height atable (* 1.2 (vla-get-rows atable)txtheight))
      (vla-put-regeneratetablesuppressed atable :vlax-false))
    (progn (alert "Keine Objekte gewählt!")(exit)))
  (command "_.UCS" "_P")
  (if  acCol (vlax-release-object acCol))
  (if  acapp (vlax-release-object acapp))
  (princ)
The table I will get:
 KoordNr.             x                            y
     001        000000,000           000000,000
     002        000000,000           000000,000
     003        000000,000           000000,000
Can you help me get to this?
BeekeeCZ: If you read this... Yes I was trying to modify your code from the last month :)...
Kind regards...
Replies (13)
Message 2 of 14
C.Utzinger
Now it works, but i need to get the coordinates...
(vl-load-com)
(defun c:<Test6 (/ :sortlst acapp acol acsp adoc atable attdata attitem atts blkdata blkname blkobj col
                   column colwidth  datalist en headers pt row ss swap  tabledata tags total txtheight widths x flt)
  ;; Lee Mac
    (LM:objectid obj))
  (defun LM:acdoc nil
    (LM:acdoc))
  (if (setq ss (ssget (list '(-4 . "<OR")
			    '(-4 . "<AND") '(0 . "INSERT") (cons 2 flt) '(66 . 1) '(-4 . "AND>")
			     '(-4 . "OR>"))))
    (progn
            tags    headers
                              tabledata))
      ;; sort by "A1" :
      (setq total 0)
      (setq txtheight 15)
      (setq pt (getpoint "\nSpecify table location:")
                     acsp
                     (vlax-3d-point pt)
                     (length headers)
                     (* txtheight 1.2)
                     (* txtheight 20)))
            widths nil)
      (while (car swap)
      (setq col 0)
      (foreach wid widths
      (vla-put-colorindex accol 3)
      (vla-setcellcontentcolor atable 0 0 accol)
      (setq col -1)
        (vla-setcellcontentcolor atable 1 col accol))
      (vla-put-colorindex accol 4)
      (setq row 2)
        (setq col 0)
          (if (= 1 col)
          (vla-setcellcontentcolor atable row col accol)
      (vla-put-regeneratetablesuppressed atable :vlax-false)))
  (if  accol (vlax-release-object accol))
  (princ)
(princ)
Message 3 of 14
SeeMSixty7
Since you need the insertion points, it would make sense to get that data as you retrieve the attribute tags and values.
Try something like this to build your table data instead. I created a function to get the attributes tags, value and insertion point for you below.
(defun GetInsPointOfAttAndValue (blockobj)
  	  (setq returnlist (list))
  	  (foreach attobj (vlax-safearray->list (vlax-variant-value (vla-getattributes blockobj)))
  	  	  (setq returnlist (append returnlist (list
  	  	  			  (list (vla-get-TagString attobj) (vla-get-TextString attobj) (vlax-safearray->list (vlax-variant-value (vla-get-insertionpoint attobj))))))
  	  returnlist
....Your Code...
(setq tabledata (list))
              ;tabledata (cons (LM:vl-getattributes obj) tabledata));your previous method
              tabledata (append tabledata (list (getinspointofattandvalue obj)));new format
...rest of your code
You will need to update how you handle the list since it will be a different format now though.
Good luck,
Message 4 of 14
SeeMSixty7
Question: Are you wanting the cords of the attribute or the block insertion?
I was continuing some effort on this then realized you might want the block insertion and not the attribute insertion points.
Message 5 of 14
C.Utzinger
I just wanted to write you 🙂
I fixed the code and saw it. I Need the insert point, not the Attribute!
Thank you...
(vl-load-com)
  ;; Lee Mac
    (LM:objectid obj))
  (defun LM:acdoc nil
    (LM:acdoc))
  	  returnlist
(defun :sortlst ( lst / mlst nlst)
    (foreach item lst
	(setq nlst (cons (assoc "01" item) nlst)))
    (foreach e nlst
	(setq mlst (cons (list(cons (car e)(cadr e))(cons "x" (rtos(car(last e))))(cons "y" (rtos(cadr(last e))))) mlst)))
			     '(-4 . "OR>"))))
    (progn
            tabledata (:sortlst tabledata)
            tags    headers
                              tabledata))
      ;; sort by "A1" :
      (setq total 0)
      (setq txtheight 15)
                     acsp
                     (vlax-3d-point pt)
                     (length headers)
                     (* txtheight 1.2)
                     (* txtheight 20)))
            widths nil)
      (while (car swap)
      (setq col 0)
      (foreach wid widths
      (setq col -1)
      (setq row 2)
        (setq col 0)
          (if (= 1 col)
  (princ)
Kind regards
Message 6 of 14
SeeMSixty7
Great, Did you get it working the way you wanted then?
Message 7 of 14
C.Utzinger
NO 😞
Just what you asked me. I need the Block insertpoint!!!
Can you fix this?
Kind regards
Message 8 of 14
SeeMSixty7
Yes I can, but I have to ask, why do you have a multiline attribute for that attribute?
Message 9 of 14
C.Utzinger
Because I have a shadow (i don't know if that is the correct word in English) behind. With a normal Text it is not possible (or is it?)
Message 10 of 14
SeeMSixty7
Ok, and just to verify we are sorting on the value of the attribute and not the x or y coordinate, right?
Will all the attribute values be a unique coordinate number? 1,2,3,4,5... seems like they should, but just want to make sure.
Message 11 of 14
C.Utzinger
Yes exactly. Every Block his number and coordinates.
Message 12 of 14
SeeMSixty7
Try this. I had to rush through the end as I re-wrote most of it. I'll check back Monday.
Good Luck,
(defun GetAttAndValue (blockobj)
  	  	  			  (list (vla-get-TagString attobj) (vla-get-TextString attobj))))
  	  returnlist
(defun c:quick( / :sortlst acapp acol acsp adoc atable attdata attitem atts blkdata blkname blkobj col
                   column colwidth  datalist en pt row ss swap tabledata header tags total txtheight widths x flt)
			     '(-4 . "OR>"))))
        (progn
			(setq KoordNumList (list)
				  xydata (list)
				  header  (list "KoordNr." "x" "y")
				(setq ent (ssname ss (setq i (1- i)))
					  entdata (entget ent)
					  inspt (cdr (assoc 10 entdata))
					  attdata (GetAttAndValue (vlax-ename->vla-object ent))
					  attvalue (nth 1 (nth 0 attdata))
					  attvalue (substr attvalue 10) ; get rid of default formatting
					  koordnumlist (append koordnumlist (list attvalue))
					  xydata (append xydata (list (list attvalue (list (car (cdr (assoc 10 entdata))) (cadr (cdr (assoc 10 entdata)))))))
			(setq koordnumlist (acad_strlsort koordnumlist)
			      total (sslength ss)
			      txtheight 15
						 acsp
						 (vlax-3d-point pt)
						 (+ 2 total)
						 (length header)
						 (* txtheight 1.2)
						 (* txtheight 20))
		    (setq cnt 0
		    	  tabledata (list)
		    (foreach koord koordnumlist
		    	(setq xy (assoc koord xydata)
		    		  tabledata (append tabledata (list (list koord (rtos (car (cadr xy)) 2 1) (rtos (cadr (cadr xy)) 2 1))))
		    (setq swap (append (list header) tabledata)
				  widths nil)
		  (while (car swap)
		  (setq col 0)
		  (foreach wid widths
			(setq col (1+ col))
		  (setq col -1)
		  (setq row 2)
			(setq col 0)
			  (if (= 1 col)
	(princ)
Message 13 of 14
C.Utzinger
Thank you... I will try tomorrow
Message 14 of 14
C.Utzinger
Just what I was looking for 🙂
Thank you very much.
Kindregards
