Message 1 of 14
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
HI
I have the attached Block and I was trying to modify the following code to extract the one Attribute, get the coordinates and create a table.
(defun c:<Test7 (/ *error* :sortlst acapp acol acsp adoc atable attdata attitem atts blkdata blkname blkobj col column colwidth datalist en headers pt row ss swap tabledata tags total txtheight widths x) (defun *error* (errmsg) (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end")) (princ (strcat "\nError: " errmsg))) (command-s "_.UCS" "_P") (princ)) ;; Lee Mac ;; http://www.lee-mac.com/attributefunctions.html (defun LM:vl-getattributes ( blk ) (mapcar '(lambda (att) (cons (vla-get-tagstring att) (vla-get-textstring att))) (vlax-invoke blk 'getattributes))) ;; ObjectID - Lee Mac ;; Returns a string containing the ObjectID of a supplied VLA-Object ;; Compatible with 32-bit & 64-bit systems (defun LM:objectid ( obj ) (eval (list 'defun 'LM:objectid '(obj) (if (and (wcmatch (getenv "PROCESSOR_ARCHITECTURE") "*64*") (vlax-method-applicable-p (vla-get-utility (LM:acdoc)) 'getobjectidstring)) (list 'vla-getobjectidstring (vla-get-utility (LM:acdoc)) 'obj ':vlax-false) '(itoa (vla-get-objectid obj))))) (LM:objectid obj)) ;; Active Document - Lee Mac ;; Returns the VLA Active Document Object (defun LM:acdoc nil (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object)))) (LM:acdoc)) ; ---------------------------------------------------------------------------------------------------------------------------- ; ---------------------------------------------------------------------------------------------------------------------------- (command "_.UCS" "_W") (setq flt "SPI-Datenextraktionspunkt-CM*") (if (setq ss (ssget (list '(0 . "INSERT") (cons 2 flt) '(66 . 1)))) (progn (repeat (setq i (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq i (1- i)))) tabledata (cons (LM:vl-getattributes obj) tabledata))) (setq tabledata (vl-remove nil tabledata) headers (mapcar 'car (car tabledata)) tags headers tabledata (mapcar '(lambda (x) (mapcar 'cdr x)) tabledata)) ;; sort by "A1" : (setq tabledata (vl-sort tabledata '(lambda (a b)(< (car a)(car b))))) (if (= tabledata nil)(progn (alert "Keine Daten gefunden!")(exit))) (setq total 0) (foreach i datalist (setq total (+ total (cdr i)))) (setq txtheight (if (= btog10 1)(* 15 0.01) 15)) (or adoc (setq adoc (vla-get-activedocument (setq acapp (vlax-get-acad-object))))) (or acsp (setq acsp (vla-get-block (vla-get-activelayout adoc)))) (setq acCol (vla-GetInterfaceObject acapp(strcat "AutoCAD.AcCmColor." (itoa (atoi (getvar "acadver")))))) (setq pt (getpoint (strcat "\n" Typ. " Tabelle einfügen:")) atable (vla-addtable acsp (vlax-3d-point pt) (+ 2 (length tabledata)) (length headers) (* txtheight 1.2) (* txtheight 20))) (vla-put-regeneratetablesuppressed atable :vlax-true) ;; calculate column widths : (setq swap (append (list headers) tabledata) widths nil) (while (car swap) (setq column (mapcar 'car swap) colwidth (* 1.2 (apply 'max (mapcar 'strlen column)) txtheight) widths (cons colwidth widths) swap (mapcar 'cdr swap))) (setq widths (reverse widths)) ;; set column widths (setq col 0) (foreach wid widths (vla-setcolumnwidth atable col wid) (setq col (1+ col))) (vla-put-colorindex acCol 8) (vla-setgridcolor atable 61 7 acCol) (vla-put-horzcellmargin atable (* txtheight 0.5)) (vla-put-vertcellmargin atable (* txtheight 0.3)) (vla-setTextheight atable 1 (* txtheight 0.8)) (vla-setTextheight atable 2 (* txtheight 1.2)) (vla-setTextheight atable 4 (* txtheight 0.9)) (vla-setText atable 0 0 "Koordinaten") (vla-SetCellAlignment atable 0 0 acMiddleCenter) (vla-put-colorindex acCol 3) (vla-setcellcontentcolor atable 0 0 acCol) (setq col -1) (foreach descr headers (vla-SetTextStyle atable (+ acHeaderRow acDataRow acTitleRow) "Simplex7-12.5") (vla-setText atable 1 (setq col (1+ col)) descr) (vla-SetCellAlignment atable 1 col acMiddleCenter) (vla-setcellcontentcolor atable 1 col acCol)) (vla-put-colorindex acCol 4) (setq row 2) (foreach record tabledata (setq col 0) (foreach item record (vla-setText atable row col item) (if (= 1 col) (vla-SetCellAlignment atable row col acMiddleCenter) (vla-SetCellAlignment atable row col acMiddleCenter)) (vla-setcellcontentcolor atable row col acCol) (setq col (1+ col))) (setq row (1+ row))) (vla-put-width atable (apply '+ widths)) (vla-put-height atable (* 1.2 (vla-get-rows atable)txtheight)) (vla-put-regeneratetablesuppressed atable :vlax-false)) (progn (alert "Keine Objekte gewählt!")(exit))) (command "_.UCS" "_P") (if acCol (vlax-release-object acCol)) (if acapp (vlax-release-object acapp)) (princ) )
The table I will get:
KoordNr. x y
001 000000,000 000000,000
002 000000,000 000000,000
003 000000,000 000000,000
Can you help me get to this?
BeekeeCZ: If you read this... Yes I was trying to modify your code from the last month :)...
Kind regards...
