autolisp can't substract two integers
Message 1 of 15
This one perplexes me.
If I run this, I get the expected result (12)
(setq value (+ 8 4))
However, if I do this:
(setq value (- 8 4))
I get this error message:
; error: bad function: 1
As a workaround I am using
( setq value (+ 8 (* 4 -1)) )
Any ideas?
thanks
Replies (14)
Message 2 of 15
cadffm
Start a new drawing, try it again.
Sebastian
Message 3 of 15
With a new drawing, substraction works fine. However, with existing drawings the error persists. Thank you.
Message 4 of 15
cadffm
After closing and re-opening this file still a problem ???
Please, share this file
Sebastian
Message 5 of 15
john.uhden
Have you tried an AUDIT on the mischievous files?
At the command prompt, what does !- return (for both the bads and the goods)?
Are the mischievous files from an older version such that some code you are loading loads say "this" versus "that" based on the version in which the drawing was last saved?  ACADVER won't tell you the version in which the file was saved, but there is an easy way to read the first 6 characters of a DWG file  to determine that.
How about if you save a "bad" drawing and reopen it?  Does the symptom disappear?  Or are you maybe saving as default to an older version?
John F. Uhden
Message 6 of 15
gcsjlewis
"value" is a command in autolisp.  So (setq value ....) will not work.  Try a different variable.  I use notepad++ when coding, and if you save the file as a .lsp, the variables will be become blue, it it is already defined.
Message 7 of 15
gcsjlewis
"value" is a command in autolisp/autocad.  So (setq value ....) will not work.  Try a different variable.  I use notepad++ when coding, and if you save the file as a .lsp, the variables will be become blue, it it is already defined.
Message 8 of 15
Kent1Cooper
@gcsjlewis wrote:
"value" is a command in autolisp/autocad.  .....
It's not listed in Help [2021], neither as an AutoCAD command nor system variable nor as an AutoLisp function.  Besides, if that were the problem, their first example wouldn't have worked.
Kent Cooper, AIA
Message 9 of 15
pbejse
Any ideas?
Could it be that you somehow redefine "-" as something else within other lisp code
(setq  - 1);<--- somewhere  in any your lisp codes
Which explains why it  works on a new drawing, until some other codes triggers the redefining of the symbol?
Message 10 of 15
vladimir_michl
Someone (some LISP code) has redefined your function '-.
You can simulate this (bad) behaviour e.g. with:
(defun - (a b)+(1))
Vladimir Michl, www.cadstudio.cz - www.cadforum.cz
Message 11 of 15
hak_vz
@gcsjlewis
In N++ if you have language selected set on LISP it stands for Common LISP. It has something called accessor  functions and one of this is "VALUE"(that's why it is highlighted blue).
For Autolisp I use this
Miljenko Hatlak
Message 12 of 15
Hi, no, opening and closing the file does not solve the problem. I cannot share the file, it contains sensitive information.
Message 13 of 15
You put me in the right track. I wasn't aware of the audit command, but when I read the docs about it I found a mention to the RECOVER command. That one did the trick. Thank you and thanks everybody for your collaboration.
Message 14 of 15
Interesting possibility. I 'll watch for that in future developments.  In this particular case, I reduced the source code to perform the substraction and nothing else. However, the error remained.
Message 15 of 15
john.uhden
@gcsjlewis
value is not a command or a function in either my 2002 or my 2020.
But it appears that somewhere in the code he loading there is  (setq - 1).
Thus...
Command: (- 8 4)
We must all be careful not to use function symbol names as variables.
John F. Uhden
