AutoLISP adding multiple atts to a block, but they're all coming in at 0
acadadmin3KNUF
acadadmin3KNUF
Hello to all:
I have a lot of blocks that I have to add the same attributes to.  I have code that is successfully adding all the atts I need...but they are ALL coming in at 0,0 in the block editor even though I tried to add code for specific insertion points.  Here is a snippet from the full code for one attribute:
(foreach blk blks
         (setq def (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) blk))
         (setq AttObj1
            (vla-addattribute def
              8
              acattributemodelockposition
              "ONE OR BOTH SIDES?"
              (vlax-3D-point 200 72)
              "SYS_DCV_SIDE"
              "default"
I've attached the LISP file and a very simple block that I've been using for testing.  Where's my error?  Thanks in advance for any help!
-didier-
Bonjour @acadadmin3KNUF
This is not really a solution, but the beginning of a solution :
If you use "acAlignmentLeft" instead of "acAlignmentmiddle"
The values of insertion points are correct.
You have to work with the options of alignment…
Sorry for my poor English.
Amicalement
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
paullimapa
I think the problem has to do with the parts of the code where you use the vlax-3D-point function.
Per on-line help the function needs to be supplied with an x coordinate followed by a y coordinate.
If you want the y coordinate to change which means it won't overlap on the same line then you need to be changing the 2nd number and not the first.
Take a look at how the vla-addattribute is implemented on this post:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-to-select-blocks-and-add-attrib...
Paul Li
IT Specialist
@The Office
