Autoliso doesn't work since Autocad 2019, HELP PLEASE!
bim8QKRA
bim8QKRA
Dear all,
I have the following autolisp which is running perfect for Autocad2018, but it doesn't work for Autocad2019.
What is the issue?
Thanks so much
(defun C:changehatchtoback ( / acblk acdoc acsel name obj processed )
(vl-load-com) (princ)
(setq acdoc (vla-get-activedocument (vlax-get-acad-object))
acblk (vla-get-blocks acdoc)
(if (ssget "_X" '((0 . "INSERT")))
(progn
(vlax-for block (setq acsel (vla-get-activeselectionset acdoc))
(if (not (member (setq name (vla-get-name block)) processed))
(lambda ( / lst )
(vlax-for obj (vla-item acblk name)
(if (AND (wcmatch (vla-get-layer obj) "*PATT*") (eq "AcDbHatch" (vla-get-objectname obj)))
(progn
(setq lst (cons obj lst))
(if lst
(vla-movetobottom (LM:SortentsTable (vla-item acblk name))
(vlax-make-variant
(vlax-safearray-fill
(vlax-make-safearray vlax-vbobject (cons 0 (1- (length lst)))) lst
(setq processed (cons name processed))
(vla-regen acdoc acallviewports)
(princ)
(defun LM:SortentsTable ( space / dict result )
(vl-load-com)
(cond
(not
(vl-catch-all-error-p
(setq result
(vl-catch-all-apply 'vla-item
(list (setq dict (vla-GetExtensionDictionary space)) "ACAD_SORTENTS")
result
( (vla-AddObject dict "ACAD_SORTENTS" "AcDbSortentsTable") )
ВeekeeCZ
Edit: It looks fine. Do you get any error?
mid-awe
I'm not sure if this can help for your version. I am using AC2020 and your code does not work for me either, but there is a built in HATCHTOBACK command and it works great. Maybe, unload your command and try to enter HATCHTOBACK @ the command line.
It could be that simple.
Hope this helps
jreidCDS28
Never knew HATCHTOBACK. Works great.
I use a Toolbar I added that uses DRAWBACK & SSX combined that I might change to HTB.
^C^Cdr;(ssx);e;hatch;;;b;
DRAWORDER;
(SSX);
ENTITY;
HATCH;
2 RETURNS;
BACK;
mid-awe
I'm glad that worked for you.
If you don't mind, I would appreciate it if you mark this as solved. Thank you.
