Delete attributes
Delete attributes
drew_dewit
Delete attributes
drew_dewit
I am looking for some LISP code to go through the drawing and delete all attribute definitions except for those defined in a list. The attributes are not contained in blocks but in the drawing itself.
ВeekeeCZ
Assuming you have a list of tags.
(vl-load-com)
(defun c:RemoveAttdefs ( / lst ss i en )
  (setq lst '("Tag1"
	      "Tag2"
	      "Tag3"
  (if (setq ss (ssget "_:L" '((0 . "ATTDEF"))))
    (repeat (setq i (sslength ss))
      (setq en (ssname ss (setq i (1- i))))
      (if (vl-position (cdr (assoc 2 (entget en))) lst)
	(ssdel en ss))))
  (if (and ss (> (sslength ss) 0))
    (command "_.erase" ss ""))
  (princ)
pbejse
Curios, why would you have ATTDEF's on your drawing? Obviously from exploded attributed blocks,  why not take it one step further and convert the excluded ATTDEF into TEXT entity.
Building off @BeekeeCZ 's suggestion
(defun c:RemoveAttdefs (/ dxf_ lst ss i en ent data)
  (setq	dxf_ '(2 7 8 10 40 41)
	lst  '("TAG1"
	       "TAG2"
	       "TAG3"
	    ent	 (entget en)
	    data (mapcar '(lambda (dx)
			    (Cdr (assoc dx ent))
			 dxf_
      (if (vl-position (car data) lst)
	(entmakex (append '((0 . "TEXT"))
			  (mapcar 'cons (Cons 1 (cdr dxf_)) data)
      (entdel en)
  (princ)
HTH
