AutoCAD2021 pop-up window in lisp
BB8x
BB8x
In old AutoCAD2014 I was using lisps with good and old LeeMac lm:listbox. Issue is in AutoCAD2021 it does not work. I spent with claude few hours and 30+ attempt to find another way of displaying populated pop-up window in AutoCAD2021. All failure, almost always lisp like that turned cursor to busy and all I was able to do is zoom in and out before forcing AutoCAD to close.
Do you know by a chance how to modify bellow or know other way to display populated pop-up window in AutoCAD2021 with Lee Mac's lm:listbox funtionalities?
;; List Box - Lee Mac
(defun LM:listbox (msg lst bit / dch des tmp rtn)
  (cond
    ((not
      (and
        (setq tmp (vl-filename-mktemp nil nil ".dcl"))
        (setq des (open tmp "w"))
        (write-line
          (strcat "listbox:dialog{label=\"" msg "\";spacer;:list_box{key=\"list\";multiple_select="
                  (if (= 1 (logand 1 bit)) "true" "false")
                  ";width=55;height=35;}spacer;ok_cancel;}")
          des
        (not (close des))
        (< 0 (setq dch (load_dialog tmp)))
        (new_dialog "listbox" dch)
     (prompt "\nError Loading List Box Dialog.")
    (t
      (start_list "list")
      (foreach itm lst (add_list itm))
      (end_list)
      (setq rtn (set_tile "list" "0"))
      (action_tile "list" "(setq rtn $value)")
      (setq rtn
        (if (= 1 (start_dialog))
          (if (= 2 (logand 2 bit))
            (read (strcat "(" rtn ")"))
            (mapcar '(lambda (x) (nth x lst)) (read (strcat "(" rtn ")")))
cadffm
I don't know if it was just a copy&paste issue (while create your post) ,
or you changed something in your lisp file, because this can't run in no version, also not in 2014.
Added a missing bracket, tried dummy values and it works as expected in newer and older version,
but I can't test it in 2021. If it doesn't work in 2021, there must be a bug. I am sure there isn't.
(Note, Lisp board is the next door. Overview of AutoCAD for windows Boards: https://forums.autodesk.com/t5/autocad/ct-p/8 )
Sebastian
BB8x
It is just a bracked, dcl seems to be not very welcome in 2021 version
Original Lee Mac
;; Displays a DCL list box allowing the user to make a selection from the supplied data.
;; msg - [str] Dialog label
;; lst - [lst] List of strings to display
;; bit - [int] 1=allow multiple; 2=return indexes
;; Returns: [lst] List of selected items/indexes, else nil
(defun LM:listbox ( msg lst bit / dch des tmp rtn )
    (cond
        (   (not
                (and
                    (write-line
                            (if (= 1 (logand 1 bit)) "true" "false") ";width=50;height=15;}spacer;ok_cancel;}"
                        des
                    (not (close des))
        (   t
            (start_list "list")
            (end_list)
            (setq rtn
                        (mapcar '(lambda ( x ) (nth x lst)) (read (strcat "(" rtn ")")))
    (if (< 0 dch)
        (unload_dialog dch)
    (if (and tmp (setq tmp (findfile tmp)))
        (vl-file-delete tmp)
    rtn
cadffm
I am not sure about what you trying to say.
It works all in 2021 the same way as in other versions.
Sebastian
BB8x
Lisp works great in 2014 in 2021 is not working as bellow
Alternatively maybe someone know how to get pop-up window via lisp
BB8x
Well,  sorted
Support file paths were not properly defined
