Script to clean up polylines with overlapping vertices and line segments
JBW_AIScripts
JBW_AIScripts
I have a process in which I clean up polyline shapes by exploding them, running Overkill, joining them again, running Overkill again, and then checking that the shapes are closed.
Often I will find that the original shapes have been rejoined in open segments because end points are not perfectly on top of each other. When that happens I have to painstakingly check every segment end by zooming in on it and attach it to the next closest point before joining it all again.
I've attached the beginnings of my code, which is essentially trying to automate what I just described.
The goal is to wind up with a set of closed polyline shapes with no overlapping line segments or overlapping vertices, without noticeably changing the original shape.
Currently I'm unsure if Overkill is running for the whole selection. I am certain that Join is only working for one object in the selection set, and that needs to be fixed. I am aware of PEDIT but I have not gotten that to work either.
pendean
Community Legend
Community Legend
@JBW_AIScripts So AutoCAD is not the best tool is you are trying to create a large-scale sign from a raster conversion for a laser cutter for example: there are way better software packages. Is that your intent?
Or are you just trying to convert a logo to autocad entities to use in your titleblocks (in which case those little tiny imperfections will never get noticed)?
IDEA: consider use BOUNDARY command to create new outlines from your conversion then just grab free LISP out there to reduce the number of vertices etc. if a Spline Conversion is not enough.
JBW_AIScripts
Regardless of if it's the best software for the job, I'm trying to use AUTOCAD to do this. I'll look into the BOUNDARY command.
cadffm
>>"I have a process"
I would run overkill first (and force the right settings in your lisp, otherwise it is depending on your current settings)
Ever tried "more professional" tools to clean up plines? (explode/overkill/join is not bad, but you skip the
I like the idea to do it on your own, I gone the same way, but did you, or not? Out there are some Tools for it.
>>"(setq sel (ssget "_CP" bbx))"
Why are you using CP bbx? I think maybe you are doing this for a specific reason?
If not, see my sample below
>> (command "_join" sel) ;; Or PEDIT, whichever works better
(initcommandversion)(command "_.JOIN" sel "")
>>"The goal is to wind up with a set of closed polyline shapes with no overlapping line segments or overlapping vertices, without noticeably changing the original shape."
Is it possible that your sample .DWG wasn't the best choice? I can't see bigger mistakes.
It's near to the optimum, just one vertic per pline is more than needed.
See Attachment
>>"because end points are not perfectly on top of each other."
Why? I can't see the issue in your sample. dwg
and if it was a closed polyline (before explode..) there is no gap.
Your screenshot is clear, but it doesn't match to the .dwg!?
Sebastian
pendean
Community Legend
Community Legend
@JBW_AIScripts wrote:
...I'm trying to use AUTOCAD to do this...
Do what please, are you are trying to create a clean pristine outline for a laser cutter?
Or just a logo conversion for titleblocks for example?
JBW_AIScripts
I have another script that uses the shapes as selection windows that fails if there are overlapping lines or vertices. For all intents and purposes, I need to get a "laser cutter" clean outline.
