Autocad structural detailing error
At My Autocad structural detailing 2014 suddenly the teinforcement menu disappeare
And work only like normal cad
rapidcad
Hi Mohamed. I think you would find better help on the forum specifically for AutoCAD Structural Detailing....
https://forums.autodesk.com/t5/autocad-structural-detailing/bd-p/346
However, my experience with AutoCAD Mechanical (another vertical product) leads me to suggest that you check your Options>Profiles tab and make sure that you didn't somehow switch to using the standard AutoCAD profile. A lot of users open AutoCAD by double clicking on a drawing file and forget that there is code in the desktop shortcut that specifically sets vertical users toward using the vertical menu in the AutoCAD program. Without this desktop shortcut being used, users sometimes find that they inadvertently launch plain old AutoCAD (Vanilla, as it is known).
Hope that helps, and if not - have a look at your forum for structural - those guys use the product and know it better than most of us.
Please select "Accept as Solution" if this answers your question.
ADN CAD Developer/Operator
