AutoCAD 2022: A lisp file that can “erase” ALL what’s inside or outside a particular boundary in one go,
JamaL9722060
Message 1 of 14
JamaL9722060
I’m wondering if there is a lisp file that can “erase” ALL what’s inside or outside a particular boundary in one go.
Jamal Numan
Replies (13)
Message 2 of 14
john.uhden
@JamaL9722060
Do a search in this forum for ssget_inside (or I'll post it again if you can't find it).
One decision you will have to make is whether you want to use a "Window Polygon" or "Crossing Polygon" method because you have to remember that while a circle, or block, or text can have its insertion point inside the boundary, there may be parts that extend outside, and vice versa.
John F. Uhden
Message 3 of 14
ronjonp
See attached ... no need for code.
Message 4 of 14
JamaL9722060
Thank you john.uhden. I would appreciate if you could provide me with the lisp file
Thanks ronjonp but I want this command so that I can use it for other drwaings
Jamal Numan
Message 5 of 14
3wood
You can also try SMARTSEL.
Message 6 of 14
JamaL9722060
Unfortunately, I’m not a developer and have no background how to write lisp files
Jamal Numan
Message 7 of 14
john.uhden
@JamaL9722060
It's attached.
John F. Uhden
Message 8 of 14
hak_vz
Try CookieCutter2  (type CC in system console)
Miljenko Hatlak
Message 9 of 14
Sea-Haven
No time for a coffee as cookie cutter is very fast used it for years.
Message 10 of 14
JamaL9722060
I have added the lisp file but appears not to be detected by the AutoCAD as per the screenshots below
What could be the issue here?
Jamal Numan
Message 11 of 14
hak_vz
@JamaL9722060
At the bottom of the code it says
(defun c:CC () (CookieCutter2))
To run lisp command in console this function name has to start with c:
TYPE CC to system console to run CookieCutter
Miljenko Hatlak
Message 12 of 14
JamaL9722060
It works like a charm. Amazing. Thank you for the help
Jamal Numan
Message 13 of 14
clindner
CookieCutter is very impressive! 👋 Thanks for sharing.
One modification I would suggest: instead of exploding the blocks that cross the selected trimming object, use the XCLIP command instead and simply clip the block. There are a few benefits of this:
  • The block is still "trimmed" even if it's a non-explodable block.
  • it retains the attribute value
  • The attribute's text value is "trimmed" as well!
  • The XCLIP option can also be applied to xrefs that cross the trimming object
Alternately, perhaps use BURST instead of EXPLODE on the block if it contains any attributes.
Please use the Accept as Solution or Kudo buttons when appropriate
Chris Lindner
CAD Technology Consultant @ onebuttoncad.com
AUGI Board of Directors
Message 14 of 14
john.uhden
@hak_vz ,
If you've got Civil 3D there is a MAPTRIM command.  It figures out the boundary from the objectS you select and you have the choice of trimming/erasing what's inside or out.  It's amazing.
John F. Uhden
