I'm looking for a way to auto sum all the attributes in my dwg and if possible, keep a live table of those totals in the dwg. Ideally, I would like to keep a total of the FTG attribute for each block type, as well as a table with the FTG, QTY & MAT (material) attributes so I can determine material totals with a formula that will multiply the ftgs with the qty. If its possible to change them to fields or mtext that will autosum, I'm open to changing the format. I've attached my dwg with the blocks I'm trying to use. Thank You
Solved by ec-cad. Go to Solution.
Have you tried Dataextraction command to create the Table. Then you can always manually add a row at the bottom then add a formula in the cell to sum the above rows. The Table can also be updated since it’s a Dataextraction
yes, I have and it does work. I'm just looking for a live table of the totals to eliminate the need for that step
If you have an existing table at any time you can add a row. "Vla-insertrows", so if you have attributes can link via a field to a block attribute cell.
Using a custom make table. So if add more blocks select table then select blocks.
Here's my take on it.
This Lisp will make a .csv file in the current folder, named 'dwgname'+.csv.
Open that .csv, adjust the Column Width as required. Mark and 'Copy' the Cells,
then in Acad drawing ..Right Click, Copyclip/Paste. That gives you an image that is
in the drawing, and can be saved with it. You may also want to select that image, and
Scale it to suit.
I'm sure Sea-Haven can make up a Lisp that just 'builds' the Table within the .dwg,
and when you need an update, just remove the existing table, and rebuild it.
See the drawing attached.
Load the Lisp, and type GO to start it up.
ECCAD
;; GET_FTG.lsp
(vl-load-com)
(defun write_to_csv_file ( S ); send in 'string', formatted as .csv
(if (findfile OUTFILE)
(progn
(setq ofil (open OUTFILE "a"))
(write-line S ofil)
(close ofil)
); progn
); if
(if (not (findfile OUTFILE))
(progn
(setq ofil (open OUTFILE "w"))
;; Header
(setq O (strcat
(chr 34) "FTG" (chr 34) ","
(chr 34) "QUANTIY" (chr 34) ","
(chr 34) "MATERIAL" (chr 34) ","
(chr 34) "BLOCKNAME" (chr 34) ",,"
)); setq/strcat
(write-line O ofil)
(write-line S ofil)
(close ofil)
); progn
); if
); function
;; Search Blocks, get the Attribute Values
(defun get_FTG_info ( )
(setq ss nil FTG-TOTAL 0); assures selection set is nil
(setq ss (ssget "X" (list (cons 0 "INSERT"))))
(if ss
(progn
(setq N 0)
(repeat (sslength ss)
(setq ent (entget (ssname ss N))); Entity
(setq BLKNAME (cdr (assoc 2 ent))); Blockname
(setq blk (vlax-ename->vla-object (ssname ss N))); Make Object of the Item
(if (safearray-value (setq atts (vlax-variant-value (vla-getattributes blk))))
(progn
(setq atts (vlax-safearray->list (vlax-variant-value (vla-getattributes blk))))
(foreach att atts
(setq Tag (strcase (vla-get-tagstring att)))
(if (= Tag "FTG"); FTG
(progn
(setq FTG (strcase (vla-get-textstring att)))
(if (and (/= FTG nil)(/= FGT ""))
(progn
(setq F (atoi FTG))
(setq FTG-TOTAL (+ FTG-TOTAL F)); SUM
); progn
); if
); progn
); if
(if (= Tag "QTY"); Quantity
(setq QTY (vla-get-textstring att))
); if
(if (= Tag "MATERIAL"); Material
(setq MAT (vla-get-textstring att))
); if
); foreach att
(map_the_data) ; returns O .. strcat of data
(write_to_csv_file O)
); progn
); if safearray
(setq N (+ N 1))
); repeat sslength
); progn
); if ss
(princ)
); function
(defun map_the_data ( ); Make a string of the data..
;; Form Output string O
(setq O (strcat
(chr 34) FTG (chr 34) ","
(chr 34) QTY (chr 34) ","
MAT ","
(chr 34) BLKNAME (chr 34) ",,"
)); setq/strcat
); function
;; MAIN .................
(defun C:GO ( ); overall function call
(setq dwg (getvar "dwgname"))
(setq dwg (substr dwg 1 (- (strlen dwg) 4))); strip the .dwg
(setq OUTFILE (strcat (getvar "dwgprefix") dwg ".csv"))
(setq MAT "" QTY "" FTG "" BLKNAME "" F 0); Init for strings..
(command "_zoom" "e")
(get_FTG_info)
(if (> FTG-TOTAL 0)
(progn
(setq O (strcat "TOTAL FTG = " (itoa FTG-TOTAL)))
); progn
); if
(princ)
); function C:GO
(princ "\n")
(princ "\nType GO to GET FTG's")
(princ)
Thanks for the feedback. Glad to help out.
IF you need any changes, please let us know. I'm sure someone here can help.
ECCAD
"when you need an update, just remove the existing table, and rebuild it."
This is the simplest way making a table with a few hundred rows is like 1 second, you must turn off the display rows as you make the build the table then display it. 3 minutes v's 1 second.
(vla-put-regeneratetablesuppressed tableobj :vlax-false)
