Auto load lisps from network
anieves228
anieves228
Hi all!
I'm brand new to lisps and I have made decent progress these pasts 2 weeks.
I'm working on autoloading lisps from our network. I put the acaddoc.lsp in the support folder and auto cad reads it. Now I want my acaddoc.lsp file to load a file from our network. Im not sure how I can achieve this. Here is my code:
;AUTO RUN UPON OPENING NEW DWG
;location: C:\Program Files\Autodesk\AutoCAD 2019\Support
(load "\\gsgfs02\\CAD\\Automation\\Lisp Routines\\TESTING\\gsg autoload.lsp")
(PROMPT "GSG AUTO LISP LOADED.")
(PRINC)
;END AUTO RUN
Thanks!
roland.r71
@anieves228 wrote:
Hi all!
(PRINC)
;END AUTO RUN
Thanks!
Welcome!
A network or UNC path starts with the servername, preceded by a double slash (all) or double backslash (Windows only)
So after adding another backslash to tell acad you realy want a backslash, your path should look like:
(load "\\\\gsgfs02\\CAD\\Automation\\Lisp Routines\\TESTING\\gsg autoload.lsp")
or
(load "//gsgfs02/CAD/Automation/Lisp Routines/TESTING/gsg autoload.lsp")
I personally prefer to use the latter.
anieves228
Awesome thank you!
And whats the latter?
roland.r71
The last option given.
So, / instead of \
It prevents problems with \ being an escape char. altogether, instead of escaping the escape char.
& it looks better.
But as I said, its just a matter of preference.
scot-65
Try this for a more predictable result
(if load fails, prompt still says it is successful).
(princ (strcat "\n GSG Auto LISP "
(if (load "[YourLoadPathHere]" nil)
"Loaded. " "Failed. ")))
(princ)
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
