associate scr files with notepad
whitney_jeff
Message 1 of 24
whitney_jeff
Recently updated Windows - current version is Windows 10 Pro, version 1809
In the previous version I was able to open .SCR files with notepad; in the current version I cannot - when I right-click on a scr file I do not even have the option to "open with".
I have tried a couple of things, but nothing seems to work.  Notepad does not even show up in Apps.
One of the things I tried was at the windows command prompt: assoc .scr=txtfile - but that did not work.
Do I have to give up and use wordpad or something similar?
Replies (23)
Message 21 of 24
pendean
Community Legend
Community Legend
You can always backup your Windows Registry as they all suggest before editing https://neosmart.net/wiki/backup-restore-registry/ and https://support.microsoft.com/en-us/help/322756/how-to-back-up-and-restore-the-registry-in-windows
Are you in a limited-access/control WIndows log-in?
Or are you using a VPN?
Or an aggressive anti-virus/anti-malware running app that may need to be turned off?
Message 22 of 24
whitney_jeff
Discussed it with the principal, and we would rather not mess with the registry.
Windows Defender, no VPN - AFAIK I have access to everything on the server, but there may be a drive I am not privy to.
I have a work-around - it is one extra click, so not a big deal, and have had a couple of ideas I will try when it slows down a little
Now when I go to Default Apps there is still a + next to .scr and when I click on it I have a choice of Notepad or look up an app in the app store, I choose Notepad but it does not stick.  Was thinking if I uninstall Notepad++ I might be able to select Notepad from "Choose a default".
Thank you Dean, for all of your suggestions
Message 23 of 24
whitney_jeff
Our IT guy was in today; he was not able to make it work with double click either - but he came up with an easy workaround - use send to, and the send to for .scr is associated with notepad.  Almost as easy as double-click.
Message 24 of 24
wepp
Works for Win7 also.
