associate scr files with notepad
whitney_jeff
Message 1 of 24
whitney_jeff
Recently updated Windows - current version is Windows 10 Pro, version 1809
In the previous version I was able to open .SCR files with notepad; in the current version I cannot - when I right-click on a scr file I do not even have the option to "open with".
I have tried a couple of things, but nothing seems to work.  Notepad does not even show up in Apps.
One of the things I tried was at the windows command prompt: assoc .scr=txtfile - but that did not work.
Do I have to give up and use wordpad or something similar?
Replies (23)
Message 2 of 24
CodeDing
@whitney_jeff,
If you right-click a file that does not have a default program to open-with then Windows 10 should allow you to select "Open with..." However, if a default program has already been selected then it will not appear like so:
I would recommend you follow the very simple steps explained HERE to change where these open by default. (my .scr files open with Notepad on Windows 10 by default).
Best,
~DD
Message 3 of 24
whitney_jeff
Unfortunately - I do not get the same menu, I am not able to get an app from the store.  I can start notepad and then change filetype to all and select the script, but that is awkward at best.
Before the update, I was able to double-click and edit the script, not now.  Attached image of properties - no way to change it to open with notepad.
Message 4 of 24
ronjonp
Have you tried Notepad++ ? It's a great editor and will integrate into right click menu.
Message 5 of 24
whitney_jeff
It was on this computer initially - I forget why (over a year ago) but I did not think it worked well for me.  Might have to try it again though.  Curse all these "improvements"!
Message 6 of 24
ronjonp
What program tries to open the file now? I have the same version of Windows and don't have this issue.
*I'm actually still on version 1803
Message 7 of 24
dbhunia
Go through This once.....
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 8 of 24
whitney_jeff
Nothing, double click yields nothing at all.
Message 9 of 24
CodeDing
@whitney_jeff,
My solution, nor my link provided, asked you to get an app from any store. The link I provided requests that you open the Default Apps location on your computer, then once there (if you follow all 4 steps) you can locate your .scr file extension to have it open with Notepad...
Best,
~DD
Message 10 of 24
whitney_jeff
sorry, but it does not.  At least on my computer.
Message 11 of 24
CodeDing
Press (Windows logo + R) then type in "notepad". Select ok. Does Notepad open then?
Message 12 of 24
whitney_jeff
Yes, it opens then
Message 13 of 24
cadffm
Assoc the *.scr wirh Notepad.exe (again) .
If you have OPEN in your contextmenu, .scr is associated with a program.
> Registry check1: HKEY_CLASSES_ROOT\.scr = (Standard) REG_SZ = AutoCADScriptFile
 and
> Registry check2: HKEY_CLASSES_ROOT\AutoCADScriptFile\Shell\open\command = (Standard) REG_SZ = C:\Windows\system32\notepad.exe "%1"
(hope it is right for Win10 too)
If "nothing" happen but a doubleclick on *.txt files works:
Then, i guess, you have a defender/anti-vir software running. Disable all software like defender/Anti-vir and try it again for a test!
Sebastian
Message 14 of 24
whitney_jeff
Please see the attached image.
If I click on (value not set) I get a New menu, with several choice.
Further up the tree there are several extensions including .scr - but I don't think I can edit those from regedit
Message 15 of 24
pendean
Community Legend
Community Legend
Assuming Windows 10...
If it does not say NOTEPAD at #9 as shown below, click on the app that is listed and choose NOTEPAD instead.
Message 16 of 24
whitney_jeff
Dean, I did that (thanks for the graphic display!) but when I get to .scr there is only a plus (+) symbol and "Choose a default" and clicking on that takes me to choose an app from the store.  I have not been able to find the native Notepad in the app store.
I can find Notepad++, so I guess I will have to use that.
Message 17 of 24
CodeDing
@whitney_jeff,
I understand what you mean by not being able to find Notepad by following my and PenDean's examples. Wow, this is frustrating! From what I've seen browsing myself, I also cannot find another way to assign that file type to open w/ Notepad..
As a last resort from me, try opening Notepad > File > Open (All file types) > open your .scr file...
... then try to save-as another .scr file (Ex: test.scr [All File Types])
...close all Notepad > try to open your test-saved .scr file.
That's my last shot Lol. Wish I could help more gahh!
Best,
~DD
Message 18 of 24
whitney_jeff
@CodeDing
Actually - you and Dean were a great help, if if it was negative.
I can go ahead and assign it to Notepad++, and will in a day or two in case something else crops up
Thanks very much to all who replied!
Jeff
Message 20 of 24
whitney_jeff
@pendean
No, I have not tried that, and I am hesitant to any regedits
I did manage to at least get an "open with" on the context menu, but I keep getting a pop-up security warning, and I cannot find a way to make the folder a trusted source.  None of the suggestions take me to the Trust Center, it is not even on a context menu.  Totally lost!
