Hello, I would like a lisp that extract "Handle" of a Block and put it in an atribute of the same block.
I have 2 problems:
First: I want to edit all blocks in drawing (include blocks in layouts)
Second: When I extract handle information its from atributes
I read this post https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/auto-number-lisp-based-on-layout-tab...
what else should i do, this is my code
(defun c:ASGHANDLE (/ bname ss1 ent entdata handle)
(setq bname (getstring"\nEnter block to give handle: "))
(if (setq ss1 (ssget "_x" (list '(0 . "INSERT") (cons 2 bname))))
(mapcar
'(lambda (x)
(setq ent (cadr x)
entdata (entget ent))
(while (/= (cdr (assoc 0 entdata)) "SEQEND")
(cond (
(= "HANDLE" (cdr (assoc 2 entdata)))
(entmod
(subst(
(vla-get-handle (vlax-ename->vla-object ent))
(assoc 1 entdata)
entdata)
(setq entdata (entget (setq ent (entnext ent))))))
(ssnamex ss1))
"No atributes found")
(princ))
Solved by ВeekeeCZ. Go to Solution.
Perhaps like this. Hopefully, your blocks are not dynamic.
(defun c:HandleAssignment ( / e i e) (if (and (setq b (getstring t "Block name: ")) (setq s (ssget "_X" (list '(0 . "INSERT") (cons 2 b) '(66 . 1)))) ) (repeat (setq i (sslength s)) (setq e (ssname s (setq i (1- i)))) (setpropertyvalue e "HANDLE" (cdr (assoc 5 (entget e)))))) (princ) )
Just a side note: If a block has an attribute named HANDLE, we are not able to get a real handle (the property) by (getpropertyvalue e "Handle"). The attribute takes priority.
