asking for a little lisp file to insert a block
Hans_Knol
Hans_Knol
Hi all,
I’m looking for a small tool that looks in the drawing if there a block (invisible) is with a specific name, lets say that the name of the block is “BlockM”, if the block exist there is nothing to do, also not a message, but if it not in the drawing it must be inserted on point 0,0. The block is available in a library what is in the search path of AutoCAD.
Hope someone can help me wit a little lisp file like this?
Hans Knol
Kent1Cooper
Something like this?  In simplest terms, it checks whether there is are any insertions of the Block already [not just whether the Block definition exists in the drawing], and if not, puts it in.  Untested:
(if (not (ssget "_X" '((0 . "INSERT") (2 . "BlockM"))))
  (command "_.insert" "BlockM" "0,0" "" "" "")
Kent Cooper, AIA
paullimapa
If you meant that the BLOCK may be already in the drawing but not necessarily "Inserted" anywhere yet then you can check for the BLOCK in the drawing database this way:
(if (not (tblsearch "BLOCK" "BlockM"))
 (command "_.Insert" "BlockM" "0,0" "" "" "")
Paul Li
IT Specialist
@The Office
