Updating DWG Properties with AutoLisp
tcoley95E9Z
tcoley95E9Z
I made this program that takes 3 inputs for a custom DWGProps field, combines them, and then updates DWGProps accordingly. For some weird reason it seems to work fine the first few days but then I get this error:
The weird thing is if I type Regen in autocad, the dwgprops did in fact get updated. Any ideas? Code below, thanks!
(defun c:dProps ()
  (setq mmIn (getstring "\n Enter Month: ")) ;Input Month
  (setq ddIn (getstring "\n Enter Day: ")) ;Input Day
  (setq yyIn (getstring "\n Enter Year: ")) ;Input Year
  (setq dateVal (strcat mmIn "." ddIn "." yyin))
  (vl-load-com)
  ((vla-SetCustomByKey
     (vla-get-summaryinfo
       (vla-get-activedocument (Vlax-get-acad-object)))
        "Issue Date"  dateVal    ;First Field = Name // Second Field = Value
 (command "-REGEN") ;Regen command to automatically show the updated props
vladimir_michl
Your structure of parentheses is wrong - see the double "(" in:
((vla-set....
Vladimir Michl, www.arkance-systems.cz  -  www.cadforum.cz
paullimapa
since you're running vl routines might as well replace:
(command "_.REGEN")
with this:
(vla-Regen (vla-get-ActiveDocument (vlax-get-acad-object)) acActiveViewport)
Paul Li
IT Specialist
@The Office
tcoley95E9Z
Good to know! Is this preferred just to keep a consistent code throughout or is it faster?
tcoley95E9Z
Thank you so much!
paullimapa
there are advantages at times to using vlisp functions instead of relying on command line like this:
https://forums.augi.com/showthread.php?67100-regen-without-using-command
Paul Li
IT Specialist
@The Office
