ASCII-UNICODE Text File Reading Issue
serag.hassouna
Message 1 of 10
serag.hassouna
I'm trying to read a file that's written in normal ASCII characters and saved in Unicode format using the FileSystemObject leaning on the following methods
  1. OpenTextFile Method
  2. ReadAll Method
The code is simply like this
(defun read-unicode->ascii ()
  (setq path "C:\\UserProfile\\somefolder\\test.txt") ;supply a real path instead
  ;Create the FileSystemObject
  (setq fso (vlax-create-object "Scripting.FileSystemObject"))
  (setq fobj (vlax-invoke-method 'OpenTextFile path 1 :vlax-true 0))
  (setq txt (vlax-invoke-method fobj "ReadAll"))
(vlax-invoke-method fobj "Close") (mapcar 'vlax-object-release (list fso fobj)) (setq fso nil fobj nil) txt ;what to return );end-defun [read-unicode->ascii]
The issue is that
Throws the error
; error: Automation Error. Description was not provided.
______________________
I've tried the methods that're responsible for writing text files, and they work fine.
P.S. The Autolisp function read-line returns the unicode equivalent result, but not the actual text that's written in normal ASCII, That's why I've decided to give the "FileSystemObject" a try.
______________
Any help and insightful responses are appreciated.
Replies (9)
Message 2 of 10
dlanorh
At a quick glance, you are not using the fso.
This invoke method has no object
perhaps it should be
(setq fobj (vlax-invoke-method fso 'OpenTextFile path 1 :vlax-true 0))
I am not one of the robots you're looking for
Message 3 of 10
dlanorh
This is also incorrect -
It should be
(mapcar 'vlax-release-object (list fso fobj))
Message 4 of 10
serag.hassouna
You're right @dlanorh, To be honest, this code is meant to be an illustrative sample, but anyway here's a modified one
  txt ;what to return
What about the reading problem with these methods {ReadAll ,ReadLine, Read, Skip, SkipLine} ?
Message 5 of 10
dlanorh
It's years since i used a file scripting object to read/write a file, and i'm not in a position to test code at the moment. I vaguely remember something about opening files for reading using the "OpenAsTextStream" Method if you want to use "ReadAll" https://docs.microsoft.com/en-us/previous-versions//hwfw5c59%28v%3dvs.85%29
Message 6 of 10
serag.hassouna
(setq txtfile (vlax-invoke-method fso 'GetFile "C:\\UserProfile\\somefolder\\test.txt"))
(setq fobj (vlax-invoke-method txtfile 'OpenAsTextStream 1 0))
The output type is the same, a "TextStream Object" like this
 #<VLA-OBJECT ITextStream 000002a1e5376490>
However, the same error arises when invoking any reading method on the "TextStream Object"
Message 7 of 10
dlanorh
This works for me in Win7 using AutoCAD2012
(defun c:read ( / path fso txtfile fobj txt)
  (setq path "C:\\temp\\test.txt") ;a small text file on my system
  ;Get the File Object
  (setq txtfile (vlax-invoke-method fso 'GetFile path))
  ;Open File Object as TextStream
  (setq fobj (vlax-invoke-method txtfile 'OpenAsTextStream 1 0));0 = read as ascii (use -1 for unicode)
  ;Read from the textstream
  (mapcar 'vlax-release-object (list fso fobj txtfile))
  (setq fso nil fobj nil txtfile nil)
  txt ;what to return
Run in the VLIDE value of txt is contents of  *.txt file
Message 8 of 10
serag.hassouna
I'm working on Windows 10 with AutoCAD 2016.
The Good news, it works fine if the file exists before running the lisp file.
However, with some added lines to echo a text string to a new file, "FileSystemObject" doesn't recognize its creation!, returns :vlax-false when invoking "FileExist" Method, and returns the same error message.
(defun c:read ( / path cmd fso txtfile fobj txt)
  (setq path "C:\\temp\\test.txt") ;a file to be created, or an already existing file
  (setq cmd (strcat "echo Hello World > " path))
  (command "Shell" cmd); echos "Hello World" to the text file
(princ "File Existence State: ") (princ (vlax-invoke-method fso "FileExists" path)) (princ "\n") (setq txtfile (vlax-invoke-method fso 'GetFile path)) ;Open File Object as TextStream (setq fobj (vlax-invoke-method txtfile 'OpenAsTextStream 1 0));0 = read as ascii (use -1 for unicode) ;Read from the textstream (setq txt (vlax-invoke-method fobj "ReadAll")) (vlax-invoke-method fobj "Close") (mapcar 'vlax-release-object (list fso fobj txtfile)) (setq fso nil fobj nil txtfile nil) txt ;what to return );end-defun [c:read]
Message 9 of 10
dlanorh
If you cut and paste these one by one onto the command line in Autocad, it returns :vlax-true.
When I pasted (command "Shell" cmd) onto the command line and pressed return there was a short delay and a brief "command shell" window flicker
This makes me think that this is an automation problem where you are creating the fso and checking if the files exists before the system has created the file. Try inserting a (vl-cmdf "_delay" 1000) [1 second wait] between the (command "shell" cmd) and creating the fso. You may have to play around with the length of the delay (integer in milliseconds) until you find an exceptable balance.
Message 10 of 10
serag.hassouna
Thanks a lot, this really did much help, it works with me from about 200 milliseconds.
The same "command shell" window flicker happens also with me when (command "Shell" cmd) is invoked.
