AS2023 Audit log interrupts batch processing
chrisjspower
chrisjspower
Hi everyone,
I am using advance steel 2023 and if I were to have a script run the command "audit" at any point in the script it would end at the completion of the audit command which opens an auditlog.txt file.
eg:
"UCS w -view swiso zoom e -purge a n audit y _vscurrent 2 _qsave "
where the "y" is in response to the request to fix errors.
If I wanted to batch run this for many drawings it would stop before "_vscurrent" and not open the next drawing.
It looks to me like acad is no longer the active application and it loses control/ability to invoke commands and my routine is effectively cancelled.
Is there a way to suppress opening of this text file, or writing to the log without opening it?
Kind regards,
Moshe-A
@chrisjspower ,
During AUDIT if some issue occur, it stops to inform the user about the issue - you agree?!
so it is Not good idea to use it in a middle of script or even at end cause it will fail to move on to the next drawing.
to run audit on a list of drawings i would create another 2 script to be run in a raw (assuming the other commands you running is script 1)
script 2,  run the wblock command.
script 3, run audit and save.
Running wblock on each drawing will do 2 things:
1) A complete purge reducing file size to min.
2) better prepare the drawing for audit (fixing errors).
Moshe
