Script help because I can't remember AutoLISP anymore
SOrman1
SOrman1
I am trying to put together a Script to create a set of PDFs, but when it does, they are saved with the name JT1 or JT2 or JT3 as I don't kjnow how to get the drawing name to appear in front of that text, but it also sends the newly created PDFs to the last folder I saved a PDF to. I would prefer it send it to "PLOTTOFILEPATH <"C:\USERS\USERNAME\DESKTOP\PDFs">. In my case, the PDFs folder on my desktop is the final destination. It just doesn't go there.
My Script:
;Plot JT1-JT3
-PLOT
Y
P - AutoCAD PDF.pc3
ARCH expand D (36.00 x 24.00 Inches)
Inches
Landscape
No
View
JT1
1=1
Center
yes
C-Grayscale.ctb
Yes
Yes
no
no
JT1
Yes
Yes
Y
P - AutoCAD PDF.pc3
Inches
Landscape
No
View
JT2
1=1
Center
yes
C-Grayscale.ctb
Yes
Yes
no
no
JT2
Yes
Yes
Y
P - AutoCAD PDF.pc3
Inches
Landscape
No
View
JT3
1=1
Center
yes
C-Grayscale.ctb
Yes
Yes
no
no
JT3
Yes
Yes
Any and all suggestions would be helpful.
Thank you
HullDrafter
pendean
Community Legend
Community Legend
May I ask why you are not using PUBLISH command to do all of this?
paullimapa
replace where you have JT1 with this:
(strcat(getvar"PLOTTOFILEPATH")(vl-filename-base(getvar"dwgname"))"JT1")
JT2 with this:
(strcat(getvar"PLOTTOFILEPATH")(vl-filename-base(getvar"dwgname"))"JT2")
JT3 with this:
(strcat(getvar"PLOTTOFILEPATH")(vl-filename-base(getvar"dwgname"))"JT3")
Paul Li
IT Specialist
@The Office
SOrman1
When I tried to use publish, it worked with Layouts and we have multiple
views on a single layout. Besides, this is fun to figure out.
SOrman1
Trust me, this works great, but it had one hick-up. It saved the PDFs to my Desktop not to the PDF folder. I can live with where they are, but, any suggestions to get it into the last folder?
paullimapa
strange...perhaps your PLOTTOFILEPATH doesn't point to your Dekstop\PDFs folder
to check enter PLOTTOFILEPATH at the command prompt and see if it returns:
<"C:\USERS\USERNAME\DESKTOP\PDFs\">
or
<"C:\USERS\USERNAME\DESKTOP\">
If all else fails enter the complete path within the script file like this:
(strcat"C:\\USERS\\USERNAME\\DESKTOP\\PDFs\\"(vl-filename-base(getvar"dwgname"))"JT1")
JT2 with this:
(strcat"C:\\USERS\\USERNAME\\DESKTOP\\PDFs\\"(vl-filename-base(getvar"dwgname"))"JT2")
JT3 with this:
(strcat"C:\\USERS\\USERNAME\\DESKTOP\\PDFs\\"(vl-filename-base(getvar"dwgname"))"JT3")
Paul Li
IT Specialist
@The Office
SOrman1
For whatever reason, it just won't go to that last folder. Thank you for your assistance. I can work with them as they land on the desktop
