Can someone help me with rewriting the below code for the the ColorX command with an exception of white color. So it should convert entire drawing to given color except white color lines.
;;;;;;ColorX - change color all object of drawing. All layer unlock and thaw
;;;;;;ColorXREF change color xref only on a current session. All layer unlock and thaw
;;;;;;ColorXL - change color all object of drawing. Objects on the locked and frozen layers are ignored
;;;;;;ColorXREFL change color xref only on a current session. Objects on the locked and frozen layers are ignored
(defun C:COLORX (/ doc col)
(vl-load-com)
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(vla-startundomark doc)
(mip:layer-status-save)
(if (setq col (acad_colordlg 7 t))
(ChangeAllObjectsColor doc col) ;_ col — color number
) ;_ end of if
(mip:layer-status-restore)
(vla-endundomark doc)
(princ)
) ;_ end of defun
(defun C:COLORXREF (/ doc col)
(vl-load-com)
(alert
"\This lisp change color xref\nONLY ON A CURRENT SESSION"
) ;_ end of alert
(ChangeXrefAllObjectsColor doc col) ;_ col — color number
) ;_ end of if
(princ)
) ;_ end of defun
(defun C:COLORXL (/ doc col)
(vl-load-com)
) ;_ end of if
(princ)
) ;_ end of defun
(defun C:COLORXREFL (/ doc col)
(vl-load-com)
(alert
) ;_ end of alert
) ;_ end of if
(princ)
) ;_ end of defun
(defun mip:layer-status-restore ()
(foreach item *MIP_LAYER_LST*
(if (not (vlax-erased-p (car item)))
(vl-catch-all-apply
'(lambda ()
(vla-put-lock (car item) (cdr (assoc "lock" (cdr item))))
(vla-put-freeze
(car item)
(cdr (assoc "freeze" (cdr item)))
) ;_ end of vla-put-freeze
) ;_ end of lambda
) ;_ end of vl-catch-all-apply
) ;_ end of if
) ;_ end of foreach
(setq *MIP_LAYER_LST* nil)
) ;_ end of defun
(defun mip:layer-status-save ()
(vlax-for item (vla-get-layers
) ;_ end of vla-get-layers
(cons (list item
(cons "freeze" (vla-get-freeze item))
(cons "lock" (vla-get-lock item))
) ;_ end of cons
*MIP_LAYER_LST*
) ;_ end of cons
) ;_ end of setq
(vla-put-lock item :vlax-false)
(if (= (vla-get-freeze item) :vlax-true)
(vl-catch-all-apply
'(lambda () (vla-put-freeze item :vlax-false))
) ;_ end of if
) ;_ end of vlax-for
) ;_ end of defun
(defun ChangeXrefAllObjectsColor (Doc Color / tmp txtstr)
(vlax-for Blk (vla-get-Blocks Doc)
(cond
((or (= (vla-get-IsXref Blk) :vlax-true)
(and (= (vla-get-IsXref Blk) :vlax-false)
(wcmatch (vla-get-name Blk) "*|*")
) ;_ end of and
) ;_ end of or
(vlax-for Obj Blk
(if (and (vlax-write-enabled-p Obj)
(vlax-property-available-p Obj 'Color)
) ;_ end of and
(vla-put-Color Obj Color)
) ;_ end of if
(vlax-property-available-p Obj 'TextString)
) ;_ end of and
(progn
(setq txtstr
(if (vlax-method-applicable-p Obj 'FieldCode)
(vla-FieldCode Obj)
(vlax-get-property Obj 'TextString))
(setq tmp 0)
(while (setq tmp (VL-STRING-SEARCH "\\C" txtstr tmp))
(setq txtstr
(vl-string-subst
(strcat (substr txtstr (1+ tmp) 2)(itoa Color) ";")
(substr txtstr (1+ tmp) (- (1+ (VL-STRING-SEARCH ";" txtstr tmp)) tmp))
txtstr
tmp)
(setq tmp (+ tmp 3))
(vla-put-Textstring Obj txtstr)
) ;_ end of if
(= (vla-get-ObjectName obj) "AcDbBlockReference")
(= (vla-get-HasAttributes obj) :vlax-true)
) ;_ end of and
(foreach att (vlax-safearray->list
(vlax-variant-value (vla-GetAttributes obj))
) ;_ end of vlax-safearray->list
(if (and (vlax-write-enabled-p att)
(vlax-property-available-p att 'Color)
) ;_ end of and
(vla-put-Color att Color)
) ;_ end of if
) ;_ end of foreach
) ;_ end of if
(wcmatch (vla-get-Objectname Obj) "*Dimension*,AcDb*Leader")
) ;_ end of and
(progn
(vl-catch-all-apply 'vla-put-ExtensionLineColor (list Obj Color))
(vl-catch-all-apply 'vla-put-TextColor (list Obj Color))
(vl-catch-all-apply 'vla-put-DimensionLineColor (list Obj Color))
(if (vlax-property-available-p Obj 'LeaderLineColor)
(progn
(setq tmp (vla-getinterfaceobject(vlax-get-acad-object)(strcat "AutoCAD.AcCmColor."
(substr (getvar "ACADVER") 1 2))))
(vla-put-colorindex tmp Color)
(vl-catch-all-apply 'vla-put-LeaderLineColor (list Obj tmp))
) ;_ end of progn
) ;_ end of if
((= (vla-get-IsLayout Blk) :vlax-true)
(vlax-for Obj Blk
(if
(vlax-property-available-p Obj 'Path)
(wcmatch (strcase (vla-get-ObjectName Obj)) "*BLOCK*")
) ;_ end of and
) ;_ end of if
(t nil)
) ;_cond
(vl-cmdf "_redrawall")
) ;_ end of defun
(defun ChangeAllObjectsColor (Doc Color / txtstr tmp txt count)
(if (= (vla-get-IsXref Blk) :vlax-false)
(progn
(setq count 0 txt (strcat "Changed " (vla-get-name Blk)))
(grtext -1 txt)
(vlax-for Obj Blk
(setq count (1+ count))
(if (zerop(rem count 10))(grtext -1 (strcat txt " : " (itoa count))))
) ;_ end of and
) ;_ end of if
) ;_ end of and
(progn
(setq txtstr
(vla-FieldCode Obj)
(setq tmp 0)
(setq txtstr
(vl-string-subst
txtstr
tmp)
) ;_ end of if
) ;_ end of and
) ;_ end of and
) ;_ end of if
) ;_ end of foreach
) ;_ end of if
) ;_ end of and
(progn
(progn
) ;_ end of progn
) ;_ end of if
) ;_ end of if
) ;_ end of defun
(princ
"\nType ColorX, COLORXREF, ColorXL, COLORXREFL in command line"
) ;_ end of princ
