Arrangement item.
Arrangement item.
xuantientutungXUK6E
Arrangement item.
xuantientutungXUK6E
hi guys,
i have a work in cutting plan which is arranged the same plates like in Dwg attached.
how can i make a lisp or any sugestion about that task.
hope you guys see the Dwg attached for more informations.
thank you.
Kent1Cooper
Mirroring that shape and Moving one of them over 10 units would not be difficult.  The challenge would be getting the up-side-down upper ones in the right places.  Can you post a drawing or image showing examples of some of the variety of shapes  that you might have?  For example, if the long diagonal edge might ever be an arc  segment, it would complicate the positioning:
Kent Cooper, AIA
xuantientutungXUK6E
here is a file dwg with varian type of plates needed to cut.
because it is to much type of shape, so it is great if can solve for these things only.test.PNG
Sea-Haven
Very tricky my 1st guess is ignore mirror for start. Maybe some rules line up on y or x value this matches image, then move to get intersect check.
