AcCoreConsole gives "command not found" error in a script that runs in AutoCAD
Message 1 of 16
I need to process a whole bunch of DWG drawings. First, i need to BURST all the blocks that are on them, and then export it to DXF format.
So, what I did is, I wrote a very small script:
(load "BURST")
BURST
ALL
_dxfout
16
and also found and modified a BAT file that some kind soul wrote here on the forum to run this script on the drawings folder:
FOR %%f IN ("C:\Users\plxru_user\Desktop\burst_test\*.dwg") DO "C:\Program Files\Autodesk\AutoCAD 2019\accoreconsole.exe" /i "%%f" /s "C:\Users\plxru_user\Desktop\burst_test\burst2dxf.scr" /l en-US
The script works perfectly in AutoCAD, but in ACC it throws an error message saying "Unknown command BURST. Press F1 for help."
Same thing happens when I try using custom PBURST from Lee Mac:
(load "C:\\Users\\plxru_user\\Desktop\\burst_test\\BurstUpgradedV1-7.lsp")
pburst
all
_dxfout
16
 I tried changing PBURST with (C:"BURST"), only to see another error "Unknown command ALL. Press F1 for help."
I have no idea about AutoLISP, scripts, etc., all I did was just slapping together the pieces that I found here on this forum.
Any advices are welcome!
Replies (15)
Message 2 of 16
xuantientutungXUK6E
i have try some codes above before and it orcurr the same problem.
so i come up with a simple solution is add acad.lsp file.
the acad.lsp file contain  s::startup ()  code which made autocad run a dwg after it open.
so use the lisp file i attached and put your lisp in. add it on appload lisp and try open all bunch of your dwg.
after finished, you unload that lisp file if you don't need it run through every open file anymore.
Message 3 of 16
Thanks for your reply, but the whole idea is about modifying the drawings without actually opening the autocad, but rather running the script via ACC.
Message 4 of 16
_gile
The Core Console works on the AutoCAD "Core" (accore.dll) so it only supports the commands which are defined with the AutoCAD Core (it does not support commands using features from acad.exe).
You can find a list of the commands thar work with the Core Console here.
Gilles Chanteau
GileCAD
GitHub
Message 5 of 16
Oh wow. Thanks for the heads up.
Maybe you have any other ideas on how to effectively burst all the blocks on a set of drawings?
Right now I use script writer that creates a script to automatically open all the drawings in a given folder in AutoCAD and run whatever you need to run. It's not as effective, because you actually have to run AutoCAD to do that, but, oh well...
Message 6 of 16
ВeekeeCZ
@Anonymous wrote:
 I tried changing PBURST with (C:"BURST"), ...
I didn't try, but the correct syntax would be: (c:burst)
Message 7 of 16
Yup, my bad, I got it wrong in my message. But still, it gave me an error of "command not found for the "ALL" line.
Message 8 of 16
cadffm
_gile: "so it only supports the commands which are defined with the AutoCAD Core (it does not support commands using features from acad.exe).
Thats right, but you can load program extensions as well.
The statement sounded (for me as a reader) not so / knowing that I do not tell you anything new 😉
@Anonymous
>"I have no idea about AutoLISP, scripts, etc., all I did was just slapping together the pieces that I found here on this forum."
No risc  No fun? Sorry, but then you shouldn't create batch jobs like that. my opinion
>"First, i need to BURST all the blocks that are on them, and then export it to DXF"
Whenever you use BURST, run a Purge command with all options first, specially for empty Texts, blocks,layers..all.
"The script works perfectly in AutoCAD, but in ACC it throws an error message saying "Unknown command BURST. "
Because the Burst program isn't loaded (Without checking it, I don't know if it can work or not).
>"I tried changing PBURST with (C:"BURST"), only to see another error "Unknown command ALL. Press F1 for help."
And thats right, "ALL" is not a valid command, or?
The command ist just NBURST / or PBURST - there are two commands defined in the *.lsp file.
What you try is ok, but the problem is: No of these two(three) commands are designed for running in accoreconsole, they can't.
You have to go another way or to find another program extension, which can load&run succesful in accoreconsole,
without the knowledge you have to test, try & error principle
Very difficult in your current situation / state of knowledge.
Sebastian
Message 9 of 16
Thanks for your detailed answer!
Well, I guess neither BURST, which i load with (LOAD "BURST"), nor PBURST are supported by ACC.
I don't really know how do I specify this ALL selection for (C:BURST) or (C:PBURST)...
Message 10 of 16
for most of the commands you can use "command" lisp function, like: (command "_.zoom" "_e")
Message 11 of 16
martti.halminen
I don't know about the BURST command specifically, but more generally, one nasty detail with AcCoreConsole (at least on 2017, I haven't tried it with newer versions): if you try to load Lisp code from a directory that is not defined in Trusted Locations in the Options dialog, ACC just quietly doesn't load it, giving no error reports about that.
Message 12 of 16
cadffm
@martti.halminen
That is the nature of automation. The creator has to take care that all possible situations can be dealt with.
For your described case:
SecureLoad would be simply switched off for automation (to load stuff from none trustedpaths), see [F1]
See that logfile:
[ AutoCAD - Fri Feb 07 12:18:51 2020 ]----------------------------------------
Befehl: (getvar "TRUSTEDPATHS")
"D:\\..."
Befehl: SECURELOAD
Neuen Wert für SECURELOAD eingeben <1>: 0
Befehl: (load "Y:\\TEST.lsp")
Loaded from a path which is not incl. the trustedpaths! <- Thats my sample PRINC inside the loaded LSP file.
Befehl: _.quit
Befehl:
Sebastian
Message 13 of 16
stevenh0616
As I'm on the hunt for something else AcCoreConsole related - I decided while it's fresh in my mind I'd follow up on @cadffm's post, you absolutely should be able to use Express tools in AcCoreConsole. In your script file that you pass into AcCoreConsole, you just need to tell it to load up Express Tools as @_gile mentioned, AcCoreConsole only initially loads up the core software. Any Extensions / Add ons need to be loaded by the developer - even if it's a simple BAT file with a Script loading.
I'm not positive how to load up Express Tools - but I believe it would be one of the following three methods in your Script file passed into AcCoreConsole:
  1. Try simply calling EXPRESSTOOLS command.
  2. In the script, load the the following file (change product year as necessary)
    • "C:\Program Files\Autodesk\AutoCAD YEAR\Express\acettest.fas"
  3. In the script, load the above mentioned fas file and then call EXPRESSTOOLS command.
If none of the above work, then we aren't calling the proper file to load up Express Tools into AutoCAD. I'm going off of this AKN page:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/AutoC...
Further, if anyone wants to access Civil 3D, that can be done as well. I would assume the same for any of the vertical products if installed. For Civil 3D, we load the core CRX file like below - again from the Script file:
arx Load "C:\Program Files\Autodesk\AutoCAD 2020\C3D\AeccCoreBase.crx"
Once that is done, Civil 3D commands and objects can be accessed / read with AcCoreConsole.
Steve Hill, Civil Designer / .NET Developer / AutoCAD and AutoCAD Civil 3D Certified Professional
http://redtransitconsultants.com/
Autodesk Exchange Store
Twitter | LinkedIn | YouTube
Message 14 of 16
Sea-Haven
I dable at edges of acccoreconsole and there was something about no VL lisp, but you may have a way around it by loading the correct ARX for VL commands. Will try (atoms-family 0) see if can dump to file etc using acc.
Message 15 of 16
Sea-Haven
The more I tested the less I found I could do with accoreconsole, tried dumping the (atoms-family 1) to a file that did not seem to work, that would have exposed commands available. I tried creating text in a dwg for the list in normal acad that worked, but not in acc. If I remember correct vl-commands do not work which is why if can load a arx etc may help
Hint Vl.arx vl.arc
Message 16 of 16
Sea-Haven
Ignore the other post did get commands list.
Bat
c:
cd\Program files\Autodesk\Autocad 2020
accoreconsole.exe /i  D:\Acadtemp\Drawing2.dwg  /s D:\alan\lisp\test2.scr /l en-us
Script
(setvar 'ctab "MODEL")
(load "commands.lsp")
zoom e
save
d:\acadtemp\comms.dwg
lisp
(setq coms (atoms-family 1))
(setq y 100)
(foreach nam coms
(command "text" (list 0 (setq y  (- y 3))) 2.0 0.0 nam)
I had the batch file wrong and as you do not see much it was hard to work out is it working, but when it does you will see lots of action.
