Visual LISP, AutoLISP and General Customization
Append a list to a list anywhere in the list
9 REPLIES 9
Message 1 of 10
Strydaris2492
386 Views, 9 Replies
Hi everyone,
I am trying to combine 2 lists of points together and I can't seem to figure it out.
I know append will combine the lists together, but what I need is a second list to be combined after the first or second or third item in the list.
For Example,
(setq ListA '((A) (B) (C)) ) ;;First list of points
(setq ListB '((X) (Y) (Z)) ) ::Second list of points
Append gives me
(append ListA ListB) = ((A) (B) (C) (X) (Y) (Z))
Cons gives me
(cons ListA ListB) = (((A) (B) (C)) (X) (Y) (Z))
I found some code from the forums that sort of does what I need.
(defun add-item-to-list (listin newitem location / i tmp)
(and
(= (type listin) 'LIST)
(= (type location) 'INT)
(not (minusp location))
(setq i (length listin))
(>= i location)
(while (not (minusp (setq i (1- i))))
(setq tmp (cons (nth i listin) tmp))
(if (= i location)
    (setq tmp (cons newitem tmp))
   );i
  );w
);a
tmp
);d
The returned result is
((A) ((X) (Y) (Z)) (B) (C)) which is a list within a list.
What I need is
((A) (X) (Y) (Z) (B) (C)) or ((A) (B) (X) (Y) (Z) (C))
Can anyone help out with this?
9 REPLIES 9
Message 2 of 10
hey there,
without pre-checks
(defun add-item-to-list (listin newitem location / listout position)
  (setq index -1)
  (while (not position)
	  (if (setq position (= (setq index (1+ index)) location))
	      	(setq listout (append listout newitem))
	        (setq listout (append listout (list (car listin)))
		      listin (cdr listin)
  (setq listout (append listout listin))
Message 3 of 10
Hi Komo,
thanks. You seem to always have a solution to my problems.
Appreciate all the help you lend out.
FYI the move dynamic block after insert still works great. It does get a little laggy if there is a lot of the same blocks inserted in the drawing.
Message 4 of 10
Kent1Cooper
in reply to: Strydaris2492
Here's one way:
(defun add-list-in-list (listOuter listInner after / tmp)
  (if
    (and
      (= (type listOuter) 'LIST)
      (= (type listInner) 'LIST)
      (= (type after) 'INT)
      (not (minusp after))
    ); and
    (progn
      (repeat after
        (setq
          tmp (cons (car listOuter) tmp)
          listOuter (cdr listOuter)
        ); setq
      ); repeat
      (append (reverse tmp) listInner listOuter)
    ); progn
  ); if
); defun
I used 'after' as an argument name rather than 'location,' because 'location' seems ambiguous -- if I give it [for example] 2, would that mean I want the added-in list placed so its first item is the 2nd thing in the result [like the positional argument in (substr)], or as the 3rd thing [like index number positions in (nth) and (ssname)]?
Uing your ListA and ListB, asking for the added list after 1 item in the base list, it produces:
Command: (add-list-in-list ListA ListB 1)
You can use the length of the "outer" list as the 'after' argument to be equivalent to (append ListA ListB), or use 0 for the 'after' to put the "inner" list in its entirety onto the front of the "outer," equivalent to (append ListB ListA).
Kent Cooper, AIA
Message 5 of 10
Moshe-A
@Strydaris2492  hi,
check this function
enjoy
Moshe
(defun append_list_in_list (ListA ListB p / i lst)
 (setq i -1)
 (foreach e ListA
  (setq i (1+ i))
  (if (= i p)
   (setq lst (append lst ListB (list e)))
   (setq lst (append lst (list e)))
 ); foreach
 lst
Message 6 of 10
ВeekeeCZ
If you have just a few members... write out the sequence one by one...
(list (nth 0 ListA) (nth 0 ListB) (nth 1 ListB) (nth 2 ListB) (nth 1 ListA) (nth 2 ListA))
Simple code, easy to understand.
Message 7 of 10
john.uhden
@Strydaris2492 ,
Here's what I have ben using for a couple of decades:
  ;; John's "New and Improved" nthadd (09-18-01) using Herman's approach of
  ;; repeat instead of horrendously slow append:
  ;; data = list being inflated
  ;; item = item (or list of items) to add to data
  ;; n    = 'INT position in data list to add item (zero counter)
  ;; multiple = 1  = item is a list; add each element
  ;;          = nil = add item as is
  ;; incorporated with multiple option (09-28-01)
  ;; Kosterized (02-02-03)
  ;; (02-04-03) corrected for VEDIT
  (defun @nthadd (data item n multiple / len head)
     (and
        (listp data)
        (setq len (vl-list-length data))
        (= (type n) 'INT)
        (>= n 0)
        (setq n (min n len)) ; corrected from (<= n len)
        (progn
          (repeat n
             (setq head (cons (car data) head)
                   data (cdr data)
          (if (and multiple (listp item)(vl-list-length item))
             (foreach element (reverse item)(setq data (cons element data)))
             (setq data (cons item data))
          (repeat n
             (setq data (cons (car head) data)
                   head (cdr head)
     data
John F. Uhden
Message 8 of 10
great to know)
Message 9 of 10
_gile
From the List library at the bottom of this page.
(defun gc:insertRange (new ind lst)
  (cond
    ((null lst) new)
    ((zerop ind) (append new lst))
    ((cons (car lst) (gc:insertRange new (1- ind) (cdr lst))))
_$ (gc:insertRange '("d" "e" "f") 3 '("a" "b" "c" "g" "h"))
("a" "b" "c" "d" "e" "f" "g" "h")
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 10 of 10
Thank you everyone.
Seems as though each one is an acceptable solution.
I went with @Kent1Cooper's solution.
AutoCAD Inside the Factory
