Help with selection confirmation
king
king
For my code below the first section for preselected entities works as intended, but using ssget in the second section requires the user to confirm the selection. The attached image shows how the code wants the user to continue selecting objects (or enter) after an object is selected
I'd like the user to:
  1. Run the command
  2. Select the entity
  3. Have layer of the selected entity be set to current without confirmation
Any ideas?
thanks in advance
(defun c:TEC (/ ss ent entLayer)
  (vl-load-com)
  (setvar "CMDECHO" 0)
  ;; First check for preselected entities
  (if (setq ss (ssget "_I"))
    (progn
      (setq ent (ssname ss 0))
      (setq entLayer (cdr (assoc 8 (entget ent))))
      (command "_.layer" "_set" entLayer "")
      (princ (strcat "\nCurrent layer set to: " entLayer))
    ;; If no preselection, prompt for selection
    (if (setq ss (ssget))
      (progn
      (princ "\nNo object selected.")
  (setvar "CMDECHO" 1)
  (princ)
ec-cad
You could use (entsel) function, as in:
  (vl-load-com)
    (progn
    ); progn
  ); if
  (if (not (setq ss (ssget "_I")))
   (progn
    (setq ent (entsel))
     (if ent
      (progn
       (setq entLayer (cdr (assoc 8 (entget (car ent)))))
       (alert (strcat "\nCurrent layer set to: " entLayer))
      ); progn
     ); if
   ); progn
  ); if
;   (if (setq ss (ssget))
;      (progn
;        (setq ent (ssname ss 0))
;        (setq entLayer (cdr (assoc 8 (entget ent))))
;        (command "_.layer" "_set" entLayer "")
;        (princ (strcat "\nCurrent layer set to: " entLayer))
;      (princ "\nNo object selected.")
  (princ)
ECCAD
CodeDing
@king ,
Nothing wrong with practicing your Lisp skills, but in case you did not know, this command exists already. It is called LAYMCUR.
See Here:
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-E44FA50E-DB98-48C4-AE6B-052ED7287497
Best,
~DD
ronjonp
@ec-cad I think the more succinct solution ( other than using laymcur ) is forcing single object selection (ssget "_:S").
