Need help with a basic script to insert a block from a resource file
acadadmin3KNUF
Message 1 of 13
acadadmin3KNUF
Hello to all:
I am trying to use scripting to insert blocks from a resource file into a dwg.  My starting code is this:
^C^C_insert;"ResourceFile";^C-insert;"*Block_1";0,0;;;
The script runs, but nothing happens...then I press ENTER and get the "unknown ccommand message.  I'm attaching a pic that shows all my source info.  Do i have the support path wrong?..., that's the only thing I can think of.  Thanks for any help 😀
Replies (12)
Message 2 of 13
Kent1Cooper
Try it without the quotation marks.  They're not needed in a command macro.  And you may need an additional semicolon at the end [your first completes the insertion point, second and third for X and Y scale factors, but nothing for rotation], unless the Block is defined for uniform scaling.
I assume the unknown command message tells you what the unknown command was -- fill us in.
Kent Cooper, AIA
Message 3 of 13
acadadmin3KNUF
Here is exactly what the command line gives in return.
Message 4 of 13
paullimapa
First of all it looks like you are in the drawing called ResourceFile.dwg and you're trying to insert a drawing that has the same name which AutoCAD won't let you do.
Second the sequence of commands you show in Notepad is NOT a script file but a macro that will only run when placed inside a menu button.
A script file containing this sequence of commands would look something like this (note the extra return after last line):
_.-insert ResourceFile _SC 1 0,0 0
_.Erase L
_.-insert *Block_1 0,0 1 0
Paul Li
IT Specialist
@The Office
Message 5 of 13
Sea-Haven
Uisng a lisp you can check does block_1 exist in this dwg, if not then go insert Resourcefile.
(if (=  (tblsearch "BLOCK" "block_1") nil)
(command "-insert" ResourceFile "_SC" 1 0,0 0)
(Command "-insert" "Block_1" 0,0 1 1 0)
Message 6 of 13
acadadmin3KNUF
Yeah I discovered that thing about the macro having to be inside a command on a menu button; i found that out after I posted the question and couldn't delete it.  I couldnt get your script text to work though.
Message 7 of 13
acadadmin3KNUF
Thanks to all that replied; I'm going to get some help from my ACAD provider tomorrow.
Message 8 of 13
paullimapa
Script files run by entering at AutoCAD's command prompt:
SCRIPT
The Select Script File window appears showing you all files with extension .SCR
Select the Script file you want to run.
In this case I named the script file ResourceFile.scr then click the Open button
Note the drawing file is named Drawing1.dwg and does not match with the name of the Block you want to insert ResourceFile.dwg
AutoCAD will then run the commands as you entered them in the Script file:
In this case I changed the Script file from my last post to look like this:
(defun script-cancel ()(command)(command "resume"))
_.-insert ResourceFile 0,0
(script-cancel)
The Script first defines a lisp function called script-cancel that would cancel the current active command and continue to resume with the next commands in the Script.
Then the Script executes the Insert command as you showed in your menu macro.
After entering the insertion point of 0,0 the Script runs the (script-cancel) function to cancel the remainder of the Insert prompts and continues to Resume to the next Insert command sequence in the Script.
Since the forum does not support the attachment of Script files, I've attached the entire Script file using extension .txt. When you save the attachment just rename the file as ResourceFile.scr. Then AutoCAD's Script command will see this in the Select Script File window.
Paul Li
IT Specialist
@The Office
Message 9 of 13
paullimapa
FYI, you may be interested in reading one of my recent articles I wrote on the topic of using Script files in AutoCAD:
AUGIWORLD by AUGI, Inc. - Issuu
Paul Li
IT Specialist
@The Office
Message 10 of 13
acadadmin3KNUF
-insert
C:/Users/matthew.neesley/Desktop/ACAD_Insert_Test/ResourceFile.dwg
0,0
1
0
The above text got me what I needed.
Message 11 of 13
paullimapa
Your macro that you posted also includes insert *block_1
Paul Li
IT Specialist
@The Office
Message 12 of 13
acadadmin3KNUF
Ok.  I'm really gonna throw you ALL for a loop.  Here's what I REALLY NEEDED, ALL of it 😁
-insert
0,0
1
0
erase
L
insert
Block_1
0,0
1
purge
b
ResourceFile
y
y
Message 13 of 13
Sea-Haven
As suggested on other posts same task using Lee-mac Steal.lsp will do what you want just pulling the one block from another dwg. It only requires like 2-3 lines of code, you just load Lee's Steal then run the call for the required block.
(if (not stealall )(load "StealV1-8.lsp"))
(Steal "C:\\My Folder\\MyDrawing.dwg"
   '(("Blocks" ("Block_1")))
I will leave it to you to download the latest version of steal.lsp.
