Anyone know of a way to group objects/blocks after they've been inserted?
I've written a small amount of code that allows me to insert a multi-line and then 2 blocks into my CAD however I'm now trying to work out how to group the three objects after they've been inserted automatically. Any help appreciated.
Kent1Cooper
You can start with the setting of a variable that holds an initially-empty selection set:
(setq ss (ssadd))
Then, after each element of the other stuff is drawn, do this to put it into the set:
(ssadd (entlast) ss)
That ss variable will then be a selection set with all those elements in it.  You can use ss for the selection in a Group [or Block?] command.
Kent Cooper, AIA
Moshe-A
Daniel Hi,
post your code and sample dwg
moshe
hak_vz
A make_group function to create group of objects from a selection set. It uses @Kent1Cooper 's random hex number generator for naming different groups (other simpler solutions are applicable).
(defun make_group ( ss / )
(defun rnd (/ modulus multiplier increment random)
  (if (not seed)
    (setq seed (getvar "DATE"))
  (setq modulus    65536
        multiplier 25173
        increment  13849
        seed  (rem (+ (* multiplier seed) increment) modulus)
        random     (/ seed modulus)
;; int2hex.lsp
;; Base-10 Integer to Hexadecimal converter.
;; Accepts positive or negative integer argument, including 0.
;; Rejects non-integer argument with Alert.
;; Kent Cooper, January 2011
(defun int2hex (int / power neg int result div remain posval)
  (if (/= (type int) 'INT)
    (progn
      (alert "Requires integer argument.")
      (quit)
    ); end progn
  ); end if
  (setq
    power 1
    neg (minusp int)
    int (abs int)
    result ""
  ); end setq
  (while (> int 0)
    (setq
      div (expt 16 power)
      remain (rem int div)
      posval (/ remain (expt 16 (1- power))); POSition VALue
      int (- int remain)
      result
        (strcat
          (if (< posval 10)
            (itoa posval)
            (chr (+ 55 posval))
          ); end if
          result
        ); end strcat & result
      power (1+ power)
    ); end setq
  ); end while
  (strcat
    (if neg "-" "")
    (if (= result "") "0" result)
  ); end strcat
); end defun - int2hex
(defun randomhex () (int2hex(atoi(rtos (* (rnd) 1e7) 2 0))))
(setvar "cmdecho" 0)
(command "_.group" "c" (randomHEX) "group_desc" ss "")
(setvar "cmdecho" 1)
(princ)
Miljenko Hatlak
