Summation of numbers with prefix alphabets not working.
Dear All,
I got a lisp code that is well working for summation of number with suffix alphabets, but not working for numbers with prefix alphabets. Please have a look on attachments and below lisp code.
(defun C:ADCC (/ cpent elist en ip newtxt pt ss sum sumtxt txt)
(princ "\n\t\t>>>  Select text to get summ >>>")
(if
;;select texts/mtexts on screen :
(setq ss (ssget '((0 . "*TEXT"))))
;; if selected then :
(progn
  ;; store the first text entity for using 'em further :
(setq cpent (ssname ss 0))
  ;; set initial sum to zero :
  (setq sum 0.)
  ;; loop trough selected texts/mtexts :
  (while
    ;; get the first text in selection :
    (setq en (ssname ss 0))
    ;; get entity list of them :
    (setq elist (entget en))
    ;; get the textstring by key 1 from entity list :
    (setq txt (cdr (assoc 1 elist)))
    ;; create output string :
    (setq sumtxt
                   ;; concatenate strings :
                   (strcat
                     ;; convert digits to string :
                     (rtos
                       ;; add to summ the digital value of text :
                       (setq sum (+ (atof txt) sum))
                       ;; 2 is for metric units (3 for engineering) :
                       2
                       ;; set precision by current :
                       (getvar "dimdec")))
    ;; delete entity from selection set :
    (ssdel en ss)
  ;; display message in the command line:
  (princ (strcat "\nSumm=" sumtxt))
  (setq pt (getpoint "\nSpecify the new text location: "))
  ;; get the insertion point of stored entity :
  (setq ip (cdr (assoc 10 (entget cpent))))
  ;; copy text entity to the new destination point :
  (command "_copy" cpent "" ip pt)
  ;; get the last created entity :
  (setq newtxt (entlast))
  (setq elist (entget newtxt))
  ;; modify entity list with new text string :
  (entmod (subst (cons 1 sumtxt)(assoc 1 elist) elist))
  ;; update changes :
  (entupd newtxt)
(princ)
(princ "\nStart command with STX...")
(princ)
Accepted solutions (3)
Moshe-A
@Anonymous hi,
it works cause the (atof) function ignore the suffix alphabet characters.
to ignore the prefix characters you need to define another function (as far as i know it  is not part of autolisp)
so i do it like the following but you need to take in consideration that if your prefix\suffix string contains numbers? they will also be return.
enjoy
moshe
(defun get-all-numeric (str / i num ch)
 (setq i 0 num "")
 (repeat (strlen str)
  (setq i (1+ i))
  (setq ch (substr str i 1))
  (if (or
	(= (ascii ch) 46)     ; decimal point
	(and
	  (>= (ascii ch) 48)  ; form zero
	  (<= (ascii ch) 57)  ; until nine
   (setq num (strcat num ch))
 ); repeat
 num
dbhunia
Also you can try this.. it works on "100 KVA" "KVA 100" "100 KVA 100" etc.
(if
(progn
(setq sum 0.0)
(while
(setq Read_Text (read (strcat "(" txt ")")))
(setq No 0)
(setq count 0)
(while (< count (length Read_Text))
(setq L1_T (nth No Read_Text))
(if (OR (= (isint_I L1_T) T) (= (isint_R L1_T) T))
(progn
(setq sumtxt (strcat (rtos (setq sum (+ L1_T sum)) 2 (getvar "dimdec"))))
(princ)
(setq No (+ No 1))
(setq count (+ count 1))
(ssdel en ss)
;; update changes :
(entupd newtxt)
(princ)
(defun isint_R (a)
(if (= (type a) 'REAL)
T
nil
(defun isint_I (a)
(if (= (type a) 'int)
T
nil
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
serag.hassouna
Check this out, I guess it would simplify the matter a little bit by separating the string-to-real extraction part from the summation part.
