Error when using vlax-curve-getFirstDeriv function
rlheath117
Message 1 of 10
rlheath117
Hi everyone,
I am writing what I thought would be a simple lisp to rotate my snapang based on a selected point of an existing entity. Part of the lisp uses the getFirstDeriv function at a selected location on the entity. The abbreviated code is as follows:
(defun c:oline ( / p1 p2 ent )
(vl-load-com)
(setq esel (nentsel "\nSelect an Object:"))
ent (car esel)
pt1 (getpoint "\nSelect Location of Intersection:"))
(princ pt1)
(setq pt2 (vlax-curve-getFirstDeriv ent (vlax-curve-getParamAtPoint ent pt1)))
(princ)
It works when I am in WCS and in a UCS if the base point is the same as the WCS base point. But, if I create a UCS that has a different basepoint than the WCS I get an error.
I think it might have something to do with a point translation of some kind but I can't figure it out. Any help would be appreciated.
Replies (9)
Message 2 of 10
Moshe-A
@rlheath117 hi,
the first argument of (vlax-curve-getFirstDeriv) and (vlax-curve-getFirstDeriv) should be VLX-object
moshe
Message 3 of 10
This is the issue which I generally used to get earlier but after taking help from Epson projector support this is the first time i am getting same error once again. How do I solve this issue, I am thinking of contacting again. It works when I am in WCS and in a UCS if the base point is the same as the WCS base point.
Message 4 of 10
Kent1Cooper
@rlheath117 wrote:
.... if I create a UCS that has a different basepoint than the WCS I get an error.
I think it might have something to do with a point translation of some kind ....
Try this [further abbreviated to essentials]:
(setq
  ent (car esel)
  pt1 (trans (getpoint "\nSelect Location of Intersection:") 1 0); current-UCS to WCS
  pt2 (vlax-curve-getFirstDeriv (vlax-ename->vla-object ent) (vlax-curve-getParamAtPoint ent pt1))
The (getpoint) returns in the current UCS, but the (...getParamAtPoint) wants a WCS location.
Kent Cooper, AIA
Message 5 of 10
ВeekeeCZ
Well, Kent was little bit faster. But it does not have to be VLX.
(vl-load-com)
  (if (and (setq esel (nentsel "\nSelect an Object:"))
	   (setq ent (car esel))
	   (setq pt1 (getpoint "\nSelect Location of Intersection:"))
    (print (setq pt2 (vlax-curve-getFirstDeriv ent (vlax-curve-getParamAtPoint ent (vlax-curve-getClosestPointTo ent (trans pt1 1 0)))))))
(princ)
Message 6 of 10
Kent1Cooper
@ВeekeeCZ wrote:
.... it does not have to be VLX.
True -- I think I know what other function I was mixing it up with that requires a VLA-object rather than an entity name.  You can omit the red parts in the second line containing red parts in my previous reply.
Kent Cooper, AIA
Message 7 of 10
rlheath117
 Kent1Cooper and BeekeeCZ,
Thanks for the replies, but I still get an error when I use it in a UCS that has a different base point than the WCS.
Are you able to use it in that case?
Message 8 of 10
Kent1Cooper
@rlheath117 wrote:
.... I still get an error when I use it in a UCS that has a different base point than the WCS.
Just the pared-down part I posted worked for me.  If you're incorporating into something larger, maybe there's something in the relationship to what surrounds it.
Kent Cooper, AIA
Message 9 of 10
rlheath117
Kent,
Sorry for wasting your time on that last reply... what you supplied worked.
Thanks to you and BeekeeCZ.
Message 10 of 10
this is really true that it might have something to do with a point translation of some kind but I can't figure it out. Any help would be appreciated but helped me to get all the detail of this.
