ANYONE KNOW HOW TO KEEP THE CMD WINDOW ALWAYS ON?
F2, txtscr, etc. toggles it, but does anyone know how to have the command screen always on?
ВeekeeCZ
CTRL+F2 ?
alexKoshman
Hi, bobafuka!
WHERE you want to see it?
1. You may resize the main AutoCAD window and give the rest of your display to Text Window if you want to see it:
a. ENTIRELY
  and
b. ALWAYS! ; ))
2. You can easily drag the top border of your Command Line Window and give it more lines if you simply want more space for Command Line Window info.
scot-65
Perhaps try docking the command line?
command LOCKUI = 0
Position (along the top or bottom of the window) and size as you see fit.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
BeKirra
Do you mean that you want to keep the command screen floating all time? - Honestly I don't know.
But assuming your monitor is bigger enough, you can dock your command screen to the bottom of AutoCAD window then drag it up for showing 5 command lines - or even more.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
