Fillet radius ends command
Using 2016 and entering a fillet radius ends the command.
It stores it and a quick space bar starts it again with the radius, but it's annoying the sh!t out of me.
Kent1Cooper
You can make a little command macro or AutoLisp routine or use the Action Recorder to call up the command and automatically feed in the Multiple option.
This is what I use for zero radius.  It wouldn't be hard to have it pause for User input of any desired radius.
Kent Cooper, AIA
dbroad
You might have something else going on, perhaps a fillet command customization.  In 2016 AutoCAD here,entering .fillet r 2 continues to prompt for the selection and does not end the command.  The ribbon fillet does the same thing.
Architect, Registered NC, VA, SC, & GA.
Kent1Cooper
@Anonymous wrote:
....  In 2016 AutoCAD here,entering .fillet r 2 continues to prompt for the selection and does not end the command. ....
There could be different interpretations of the word "continue" -- in Acad2016 here, it does go on after giving it a radius to ask for things to Fillet, but only once, and doesn't "continue" repetitively as happens under the Multiple option.  @Anonymous, does it really end completely with only the giving of a radius value, without even letting you Fillet once [unless you recall the command]?  Does the same happen if you use the period prefix as @dbroad indicates, to get the native command in case you have some kind of redefinition of it?  And are you looking for only that much continuation, or for continuous/automatically-repeating operation [which the routine I linked to does]?
Kent Cooper, AIA
These days just hold down the shift-key if you wish to "zero radius" a corner. Doesn't overwrite any predetermined radius value in doing so.
